D6b part# help
D6b part# help
Showing 1 to 7 of 7 results
dogwalkin
Send a private message to dogwalkin
Does anyone have handy a couple of part #'s for d6b
I need a "Regulator" or thermostat as I call it.
Also the gasket for the sediment bowl on the fuel pump.
Thanks for everything.
Sun, Sep 23, 2018 10:13 PM
I haven't ever seen a sediment bowl on a fuel pump---do you have a pic??
Mon, Sep 24, 2018 2:25 AM
catsilver
Reply to dpendzic:
There was a small steel sediment bowl under the fuel transfer pump on the D333 and D330 4.5" bore engines.
Mon, Sep 24, 2018 3:19 AM
dogwalkin
Reply to catsilver:
That small sediment bowl is the one I'm talking about.
Mon, Sep 24, 2018 4:06 AM
Reply to dogwalkin:
The rubber gasket for the bowl is 9H2770. Dont have a number for the regulator.
Mon, Sep 24, 2018 4:24 AM
Thank you received: 20
Takes a s/n to get the right regulator.
Mon, Sep 24, 2018 7:28 AM
dogwalkin
44a11367 is the serial #. I forgot earlier to ask about the gasket for the regulator also.
Mon, Sep 24, 2018 7:40 AM
Reply to dogwalkin:
2S4044 Regulator and 8M1589 gasket.
Mon, Sep 24, 2018 8:49 AM
