D6B oil pan plug size?
Showing 1 to 6 of 6 results
Hdonly
Send a private message to Hdonly
Wanting to get the right socket for the oil pan plug before I get ready to change the oil. I have heard 1 1/8" hex, 15/16" hex, 3/4" square. Anyone know for sure? Ya, I know I could just crawl under there and look, but I don't crawl so good anymore and I don't see so good anymore either where it's dark. haha
Sat, Feb 9, 2019 8:58 PM
seiscat
The drain plug is a inverted tapered hex. Most people just weld a nut to a bolt and use a socket on it. That works but Caterpillar makes a special socket that has the correct fit.
[attachment=52657]DP 1.jpg[/attachment] [attachment=52658]DP 2.jpg[/attachment] [attachment=52659]DP 3.jpg[/attachment]
Part number 212 8146. It is nice and will fit all the drain plugs on your tractor but it is a little expensive, I think it was $40 - $50 or so.
Craig
Sat, Feb 9, 2019 10:18 PM
seiscat
Reply to seiscat:
Craig
The small size hex looks like a 1" nut will fit. The large hex looks like 1-1/4".
Craig
Sat, Feb 9, 2019 10:24 PM
Thank you received: 140
Reply to seiscat:
Craig
Hi Folks.
I think the actual hex sizes are 15/16" for the small one - a 5/8 UNC nut - and 1 1/8" for the bigger one - a 3/4" UNC nut.
Sun, Feb 10, 2019 1:21 AM
I could be wrong, but I think if you want to taper the hex to fit the socket perfectly, you start with the larger sizes, but the smaller dimensions are common standard sizes and will fit without any grinding.
Sun, Feb 10, 2019 2:01 AM
Hdonly
I went ahead and ordered the tool from Caterpillar. It was $30.32 through my local dealer. Thanks all!
Mon, Feb 11, 2019 11:46 PM
Thank you received: 93
Reply to Hdonly:
often times these plugs get really tight because they were screwed into a hot sump with the plug cold--plug expands and gets tighter--especially true for tapered plugs--let the plug sit loose for a minute or so to equalize in temperature before torquing up.
Other thing is if the plug is really tight on the copper washer is to give the flange face a few light raps around it with a hammer to crush the gasket a bit and ease loosening.
Just because there is a 1/2" drive in the middle of the tool it does not have to be used to loosen a tight plug-- be careful not to get carried away with your 1/2" drive bar as you can shear the square off--simply use a suitable ring/box spanner if applicable or a suitable 3/4" drive socket and bar on the exposed plug tool hex.
Tue, Feb 12, 2019 8:07 AM
