D6B fuel injector problem
Showing 1 to 6 of 6 results
mattwilliams
Send a private message to mattwilliams
Guys looking for some advice on a fuel problem with a D6B 44a. It has set for about 2 years with real old fuel that is varnished smelling. Was running OK two years ago but had a miss on a cylinder. Went this week and put new injector nozzles on, changed fuel filters and ran a clean axillary tank to test with. Old nozzles had a bunch of debris on the screens so I assumed that was my problem.
I went to crank it over with the injector lines removed and fuel was only coming out of the 3 lines at the pump closest to the radiator. Sprayed cleaner down the other 3 and dirty fuel started slowly seeping out.
If the pump was dry or bad fuel for that long could the plungers be stuck or bad ? Today I went out and I am getting a good pop of pressure off the pump closest to the radiator, but the other 5 have fuel coming out but almost no pressure. Also no matter what position the throttle/governor are in I get the same amount of fuel. The #1 cylinder will fire when I hook it up but not the rest.
Any insight would be appreciated before I take the pump off and send it to the injection shop.
Matt
Thu, Mar 24, 2011 5:46 AM
If it's been sitting that long and the fuel gummed up it probably just needs a good cleaning......and yes dismantling is a requirement.
Thu, Mar 24, 2011 6:00 AM
u-joint
Send a private message to u-joint
diesel does not go bad in two years? i have started tractors that have sat twenty years and still have that fuel in the tank. unless you have a fungus growing in your fuel. the fungus grows between your diesel and water in a thin layer between. not real familiar with the 44A's but i believe they have the same scroll fuel system as the D333C.
those have a small fuel screen buried at the injection pump. they are real hard to see,
between the pump and block. follow your fuel supply line to see if it goes to a fuel screen. the ones i have been around are about the size of a D size battery. they are hard to see and do plug up, especially if you have a fungus in your fuel. the fungus will be in this screen and is a real slimmy substance.
otherwise it sounds like you may have air in the fuel system. i would try every option before pulling your pump. remove your glow plugs so you can crank the engine faster and easier and see if you can get fuel to the other five injectors. sometimes they bleed real hard, takes some time to get them bled out.
Thu, Mar 24, 2011 12:31 PM
4x6zh itzik
Send a private message to 4x6zh itzik
Reply to u-joint:
Try to release the pipe of No. 3
on his connection to pump
Inserted into the pump detergent
Even brake fluid.
Looks like an internal pump failure
Plnger Stuck
Internal blockage
Sure you have good compression.
Before you start to dismantle
Do all the basic tests
itzik
Reply to 4x6zh itzik:
Even brake fluid.
Plnger Stuck
Internal blockage
itzik
This is what Cat has to say about fuel storage and life......anything beyond is a crap shoot.
Thu, Mar 24, 2011 10:30 PM
mattwilliams
I can spray cleaner down both #2 and # 3 pumps and air gurgles back to the filter. Seems like the plungers are both stuck open. No matter what the revolution of the engine is and governor position is.
What tool and can I remove the plungers from the top of the pump externally ? Also how do you check lifters on these since there is no side plate ?
Thanks for the help
Sat, Mar 26, 2011 10:14 PM
Reply to mattwilliams:
Thanks for the help
Takes several special tools to work on the compact fuel injection,
1M6952 splined socket to remove the retainer bushings
1M6954 extractor to remove the injection pumps
8M530 rack positioning micrometer gauge
2M5219 gauge and 4"-5" depth micrometer to set timing through the pump bore.
Sat, Mar 26, 2011 11:16 PM
