D6B 44A Hard to pull steering clutch
GBCat60
Send a private message to GBCat60
On my D6B the left steering clutch and only the left is much harder to pull than the right. It also does not return forward without pushing it unless you have it pulled back and let go. The oil level is fine. The right clutch functions as it should.
Can anyone tell me what the issue is?
THANKS!
D6B 44A
Sadly the Cat 60 is gone.
Thu, Nov 19, 2015 10:48 AM
catsilver
Sounds like a tight linkage problem, also try loosening off the right clutch until its adjustment is correct, then check the left one again.
Thu, Nov 19, 2015 2:16 PM
Thank you received: 22
Reply to catsilver:
The booster is pretty much bullet prove but it is sensitive to proper adjustment. Also be sure that the levers/linkage completely return to the stops or one side can affect the operation of the other.
Thu, Nov 19, 2015 10:44 PM
