More heat, more tapping!
You're not missing anything- chill the motor and heat the bracket and tap tap tap
More loose juice and tapping. There is a space between starter motor and bracket you can use a pry bar when tapping,another pair of hands helps.
Lots and lots of anti seize when you put it together.
