D69U shift pattern
D69U shift pattern
Larry in phelan
Send a private message to Larry in phelan
Can anyone help me with the shift pattern on a d69u 17225 ? I have most of the manuals so far but not the operators. Just got her out of moth balls last weekend and still doing some cleaning and adjusting. Am I correct on it being a 1954? She has a No. 25 CCU and Cat cable blade . Thanks in advance . Larry
Sun, Jan 8, 2012 10:55 AM
bob
Send a private message to bob
Just get her running Larry. Then select every gear and inch up on the clutch, you will see then. One lever that only goes back and forth is the Johnson Bar in Railroad speak or the reverser, it shifts all speeds from forward to reverse except high gear that is beyond the reach of the reverser.
Later Bob
Sun, Jan 8, 2012 11:19 AM
Thank you received: 50
Reply to bob:
Later Bob
1954 is correct.
Sun, Jan 8, 2012 11:30 AM
Larry in phelan
1954 is correct.
Thanks O.M. What would we do without you !!!!!
Sun, Jan 8, 2012 11:51 AM
