D69U questions
D69U questions
Showing 1 to 6 of 6 results
Cat boy
Send a private message to Cat boy
Hey guys been a while since I was on here, but I'm looking at a D69U, haven't seen it in person, but the owner has records on the repairs, he bought it in 98 with a fresh engine, transmission, and the finals rebuilt. Says he may have put about 400 hours on it, aside from the D8k and two D9Hs I have for work, I just want a good little dozer to play with, and for 6500 I think it may be worth it, all I'm worried about is parts and other issues you guys may know of
Fri, Feb 1, 2013 3:11 AM
rjh-md
Ithink that I would be evaulating the undercarriage condition to see if the price is right .Most of the operating costs involved in crawler tractors is spent on undercarriage.
Fri, Feb 1, 2013 3:49 AM
X2 on the tracks. That's a good price if everything is like he says and the undercarriage is good. There are options that make for a nicer machine. Most are the late changes, just before the D6B came out, but at 13263 the oil clutch was introduced. Late changes include grease track tensioners, double V-belt fan drive etc.
Compare specific repairs to the machine to ensure each was done๐Ÿ˜†.
Then see it started from cold, warmed up and operate it before you decide.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Fri, Feb 1, 2013 4:31 AM
Cat boy
Went and looked and operated dozer, barley bumped the starter and she came right to life, transmission shifted good, clutch, and steering clutches worked great. Cable control had a lot of slack in the lever. But the main killer of this deal was while I was working her. Pushed a small pile, had great power no misses or white smoke, but the right side track near about skipped a link when I put her in reverse. Got off and looked and the right hand side had only one working roller, the rails where ate up from rubbing on the track guards, the left side was fine. For 6500 bucks it would have been worth it, if I didn't have to put 10k worth of work on the undercarriage just to make the old girl workable. ๐Ÿ˜†
Sun, Feb 3, 2013 11:54 AM
Oil Slick
Reply to Cat boy:
Cat Boy, you don't say were your located, I'm in bakersfield Ca . But I have some near perfect undercarriage for a D6 U series. The plan was to put the tracks on my R5 unless I sold the tracks for enough $$$
Mon, Feb 4, 2013 11:36 AM
Cat boy
Reply to Oil Slick:
I'm down MS, I think I'm just gona wait on buying a dozer right now. I have a D9 already getting a rebuild so I don't think I should waste money on another dozer๐Ÿ˜†
Wed, Feb 6, 2013 1:25 AM
Cat boy
Reply to Cat boy:
This dozer was in great shape, except when I went to drive it the tracks came off, guy never changed a roller on it, what a waste
Thu, Jul 11, 2013 5:23 AM
| Kingaroy, Queensland
