D69U part number needed
johnstone
Send a private message to johnstone
Pony flywheel came off the crankshaft ...... lost the key. Anyone know the part number of the key between the pony crank shaft and the flywheel? The dozer is a 1957 vintage with a serial number in the 26,000's. Would like to check in partstore and see if Cat has them.
Thank you, John
1954 D47U, 1957 D69U, 1987 JD 950
Wed, Sep 12, 2012 4:27 AM
willwingo
Thank you received: 8
The part # is 1B8730.
I believe it is a standard woodruff key- should be a parts/ hardware/ McMaster Carr store item.
Wed, Sep 12, 2012 6:12 AM
johnstone
Reply to willwingo:
Thanks Phil, but the 1B8730 is the key for the D2/D4 pony.....it is 1/4" thick. What I'm looking for is 3/8"thick by about 1 1/4" long. I stopped at a couple hardware stores on the way home and they had nothing that big. McMaster Carr most likely has them but I'm not exactly sure of all the dimensions. That's why I figured to get them from Cat.
Hope someone has that part number handy.....Thanks, John
Wed, Sep 12, 2012 7:07 AM
willwingo
Reply to johnstone:
http://www.mcmaster.com/#woodruff-keys/=j92z5k
Wed, Sep 12, 2012 7:55 AM
My 9U13263 - 9U29764 Parts book shows a 5F8453 part number and no interchange.....might be an odd ball Cat item.
Wed, Sep 12, 2012 8:04 AM
johnstone
Phil and OM, thanks for all the help....John
Wed, Sep 12, 2012 9:04 AM
