D69U oil and filter change
Showing 1 to 10 of 13 results
johnstone
Send a private message to johnstone
Today I did my first oil and filters change on my 9U.....ran into a few things I did no expect. Cleaned all the crap at the hole in the belly pan and got the plug out of the oil pan and all the oil came flowing out into my large pan on the ground...so far so good. next I removed the covers from the oil filters. the left came off fine and exposed the disposable filter. When I loosened the right one, the top came off ok but the housing also became loose and oil started to leak from the bottom of the housing....the housing was loose and could be spun around but would not come off...is there a way to tighten the housing onto the base?
I could not get to the drain plug at the bottom of the filter base...the belly pan is in the way. The filter housing stayed 1/2 full of oil and did not drain out...is this normal? There was only disposable filters in the cannisters and not the metallic strainer elements like the book shows...is this ok, or do I need to get some? Sorry about all the questions but it seems like nothing is ever simple!
John
1954 D47U, 1957 D69U, 1987 JD 950
Sat, Dec 15, 2012 7:47 AM
Not unusual to have the filter can get loose, they really depend on the top through bolt to hold them down. They are retained by a sort of flat and curved friction washer affair that ain't the greatest. A little metal rework with a hammer usually tunes them up after you take the assembly apart which requires a home made long deep socket.
Apparently you have the full flow filter conversion which uses the disposable cartridge.
Usually the oil will drain down on it's own but may take awhile but that's what the drain plug is for.
Sat, Dec 15, 2012 8:47 AM
If that housing came loose as he describes, then would/should there be an O-ring same as the top?
Inquiring minds may need to know.....
Sun, Dec 16, 2012 1:31 AM
Inter674
Reply to drujinin:
the retainer washer below the nut and spacer has bent. Getting the central nut out is a PIA requiring a 1 7/8" (?) tube spanner, and the O ring which is square in profile is a smaller diameter than the top one. I stupidly dismantled mine, throwing the old O rings out before the filters arrived, only to find the o rings did not come with the filter. Argh....now I have to find where to get them.
So I would leave them alone as long as they look OK, the unit will seal back up again. Use an oil sucker/filler device to get most of the oil out, the rest should not matter too much..
Sun, Dec 16, 2012 1:49 AM
ThomasFrazier
Send a private message to ThomasFrazier
Reply to drujinin:
[quote="drujinin"]If that housing came loose as he describes, then would/should there be an O-ring same as the top?
Inquiring minds may need to know.....[/quote]
There is an o ring at the bottom of the cannister. These harden with age and will often leak once the cannister breaks loose from the base. The old o rings have to be picked and dug and pried out of the groove. I've seen them harden to the extent you would bet you were down to the bottom of the groove when you were not. Just a little time and patience will do the trick. The o ring is like the square one in the groove of the cap.
Sun, Dec 16, 2012 1:55 AM
John from Fresno
Reply to ThomasFrazier:
Okay,
Here is what you do. Go to a local swap meet or yard sale and get you a "No Name" socket the correct size. I tend to get 3/4" drives that are 6 point. You don't want to buy and expensive Proto or Snap On. Cut the socket in half and weld a section of pipe in between the two socket halves. See picture. Then you can remove the can and replace that old hard square gasket at the bottom. Now, you can take another square gasket that is too big in diameter and just cut it at a 45 degree angle with a new single edge razor blade. Then take a new tube of super glue and glue it together to make the new smaller diameter. You should cut it so the can when squeezes down actually squeezes the 45 degree joint together. So the joint should not be vertical when installed but rather horizontal.
I hope this helps,
John
Sun, Dec 16, 2012 2:40 AM
fordhook
Send a private message to fordhook
Reply to John from Fresno:
Okay,
I hope this helps,
John
I think those o-rings are still available through the caterpillar parts system.
Sun, Dec 16, 2012 4:32 AM
johnstone
Reply to fordhook:
I let the oil drain overnight and there is still about 1 inch on the bottom of the filter cans. What is keeping that oil from draining out to the pan?......is there some restriction between the filter can and the oil pan?....is it sludge or what?
Hey OM, what is a full flow conversion,.......is it just changing from an inner element plus a metallic strainer element like the book shows to one element like I have in the picture?
Hey John from Fresno, that is a good idea on how to make a tool to remove the filter can. I will keep my eyes open for a socket the right size next time I'm at the flea market. Can anyone confirm that it is 1 7/8" as Inter674 mentioned?
Those orings for below the can are available through Cat.....$4.06
John
Sun, Dec 16, 2012 6:23 AM
johnstone
Reply to johnstone:
John
Here it is....[attachment=15700]DD6 oil filters 001.jpg[/attachment]
Sun, Dec 16, 2012 6:26 AM
Reply to johnstone:
Your tractor has the full flow conversion parts that uses the disposable cartridge filter. Takes a 1-3/8" socket on the full flow conversion retaining nut. (Takes a 1-1/2" socket if you are removing the old by-pass guts)
Sun, Dec 16, 2012 6:54 AM
Forgot one of your questions...
Slow oil drain back may be a good thing as the oil has to travel back though oil pump clearances. I'd have to check the oil flow diagram but you may be getting oil draining back from the oil cooler as well.
Mon, Dec 17, 2012 11:09 AM
