D69U inoperable brake
Showing 1 to 10 of 13 results
clark4u9u
Send a private message to clark4u9u
D69U brakes. Non-op began with the right turning brake.
I removed the access covers at the rear of the tractor. I found perhaps 4 handfuls of grease (and a small amount of cruddy oil) in each compartment. I removed all of the grease that I could by hand. Poured in diesel and stirred by hand and by using an axe handle. Drained. Repeated this process 3 times. Neither brake works now; I think this was caused by the diesel washing. So as a minimum the brake lining must be replaced.
I think that some grease remains at the bottom. I can work some more on grease removal, but the big question I have: where did the grease come from?
Source 1: from greasing the steering clutch release bearings. Source 2: from greasing the track roller frame outer bearing. Source 3: other?
The large amount of grease suggests that accumulation has happened over a long period of time. That both compartments had about the same amount of grease to me suggests that if Source 2 is the reason, then both bearings with attendant seals wore out. I think this is unlikely. But I will value your conclusion/experience.
Mon, Dec 17, 2018 5:15 AM
The source of the grease is the clutch release bearings. The outer fitting on the sprocket or track frame support cannot get into the steering clutch compartment.
I would not give up yet. A proper clean with a volatile solvent might cost a bit, but should restore the braking performance without disassembly. Might even get it with some fresh diesel or kerosene. I would be inclined to put some gasoline in the diesel to get it to cut the grease faster, but you will have to be especially careful about sources of ignition. Might be best to stay with brake clean.
Mon, Dec 17, 2018 9:30 AM
JackD6-5R
I had gear oil on brake lining on a D6 9U , took the cover off and sprayed engine degreaser on lining several times it seemed to help.
Tue, Dec 18, 2018 2:22 AM
clark4u9u
Reply to JackD6-5R:
I have to admit I am not experienced, but which cover? Beneath the fuel tank or at the back of the tractor??
Tue, Dec 18, 2018 5:41 AM
Either or both!
Tue, Dec 18, 2018 6:35 AM
JackD6-5R
Either or both!
I took the cover under the seat off but you have to remove floor pan and on right side the brake lock assembly.
Tue, Dec 18, 2018 10:39 AM
Online
Thank you received: 12
Reply to JackD6-5R:
With proper lifting equipment on hand, I would recommend pulling the fuel tank to get a much better look at things.
Another things to check out for a grease leak would be the hose that carries the grease from the fitting on the deck to throw out bearing.
Also it is possible the brake lining is just worn out.
Wed, Dec 19, 2018 6:22 AM
TOGNOT
Reply to Ray54:
in my experience with this model, you must removed the final drive (dry side) plug AND the brake adjustment bolt to empty the cavity of fluid. also, diesel doesn't really work to clean brake shoes IMO.
of course gasoline is dangerous........ but works.
if your power steering pump is leaking that could be the source of brake contamination....
lastly - you don't NEED a hoist to pull the deck cover. empty the tank as best you can, then using lumber pieces, on one side then the other, raise it up and forward. once you have the deck cover off you can see your brakes clearly.
don't for get there are access covers on the back of the case - about 6" square ? you may decide to introduce you flush liquid through those spaces.
lastly #2 - after flushing or cleaning your shoes, drive it around for a while. heat may give you some encouragement and they may start working.
Wed, Dec 19, 2018 9:03 AM
Reply to TOGNOT:
[quote="TOGNOT"]in my experience with this model, you must removed the final drive (dry side) plug AND the brake adjustment bolt to empty the cavity of fluid. also, diesel doesn't really work to clean brake shoes IMO.
My response........the plug that needs removing has nothing to do with final drives, it is in the bottom of the steering clutch compartment well inboard of the final drive. There is no dry side of a final drive on a 9U tractor, when it is removed from the tractor, the bull gear is exposed. The OP has certainly found the plug already. I am sure removing the brake band support screw would drain a bit more liquid but would have a hard time getting chunks of old grease out the approximately 3/8" hole...............I agree on gasoline or other volatile solvent
My response.......steering booster pump is in the center over the bevel gear compartment, its input shaft seal does commonly leak and drop the oil into the bevel gear/transmission gear case. If the steering booster output shafts seals are leaking, that 30 wt oil would go into the steering clutch compartments. This does happen, so if you are refilling the steering booster regularly and getting lots of lighter weight oil in the steering clutch compartments, that would be a likely source. The other sources of oil would be bevel gear shaft seals and the final drive pinion shaft seals but these should be filled with gear lube.
[/quote]
I understand what you are saying and agree with you, just don't want to confuse the OP with terminology he is unfamiliar with.
Wed, Dec 19, 2018 8:40 PM
TOGNOT
[/quote]
CCjersey, thanks for the de- cipher. I admit things that are clear in my mind quite often make no sense to others 😖mile:
Thu, Dec 20, 2018 10:55 AM
u-joint
Send a private message to u-joint
Reply to TOGNOT:
use kerosene to wash your compartments. you will want to verify your rubber grease hoses going to the release bearings are not rotted and dumping grease into the compartment instead of into the bearing. unless you are going to religiously drain your compartments or you run in water leave those bottom plugs out! it does not take much oil and its into the bottom of the brake drum. you should not need to replace your lining unless your lining is wore out. get your brakes adjusted up per the manual and they will work.
Thu, Dec 20, 2018 12:24 PM
| Hartley - South Australia
Newby Hall Tractor Fest
