d69u hydraulic pump universal
bcguide
Send a private message to bcguide
I wish I knew about this site when I had my 8u, it would have saved me alot of time and money.
Any way today I remover the belly pan to clean it out drain oil from the trans and clutch and I noticed that the universal for the hydraulic pump needs to be replaced. So the question is does anyone know what the numbers for the universal joint?
Tue, Sep 6, 2016 12:16 PM
The universal joint itself is an aftermarket # UJ934 now supplied by SKF, about $20. If the yokes are buggered up they are no longer available and you would have to source good used.
Tue, Sep 6, 2016 10:13 PM
Newby Hall Tractor Fest
