D69U Head removal procedure.
Showing 1 to 7 of 7 results
danda
Send a private message to danda
Questions:
1) Can anyone describe the procedure for removing the heads on a D69U, or point me towards a description or video? In particular, the compression release rod goes through both rocker assemblies and I don't see how to remove it.
2) I also have a running Cat 3306 engine in an old dumptruck I'm not using. I'm wondering if that would bolt up, or in general if that could be a viable option to re-power the D6.
Background:
A neighbor gave me a D69U that's been sitting in a field since about 2008. Pony motor runs good, but diesel engine is seized because he left it without exhaust cap for a few years. He had already tried dumping diesel down the exhaust and putting a big breaker bar on the engine. no go.
Today I removed the injectors and poured some marvel mystery oil down them. Well, all but one injector.... the first one (closest to radiator) is stuck tight and would not budge with a 1/2" breaker bar plus short pipe. I'll try again later with bigger breaker bar and bigger pipe. I'm wondering if this is a sign that it's the bad/worst cylinder. I also took the valve covers off, and I see that the exhaust valve is open for that particular cylinder and there is some visible rust.
Anyway, if I can't free it up via the injectors then I guess the head probably needs to come off. I already tried to remove one of the rocker arm assemblies, but it was complicated by the fact that the compression release rod runs through both assemblies and there's no clearance front or back to slide it out. Does the pony motor (and/or radiator) have to come out first or something?
Tue, Feb 16, 2016 6:45 AM
Only way I have ever had the rockers off is to take both boxes off as a unit. I needed to harvest a single rocker arm off an engine sitting on the ground with no pony in the way. Its not easy, but you can remove the decompression shaft by loosening the clamp bolts on the cams that ride on the detent ball in each box. Be careful to catch both detent ball and spring as well as the tiny woodruff key that keys the cam to the decompression shaft.
I would just take loose the two small oil feed lines and the decompression lever linkage and lift the whole kit and caboodle off as a unit.
There would be lots of things that you had to modify to drop a 3306 into a 9U. I would find a good runner or overhaul the engine you have. If you have a good head, block, crank and connecting rods you can have a good engine of known quality.
An impact gun will sometimes rattle things like that loose, I would try soaking it and applying heat to the nut and letting it cool. Have seen the whole PC chamber break loose on one before the hold down nut came loose when using a breaker bar.
Tue, Feb 16, 2016 11:38 AM
danda
Thanks for the detailed reply ccjersey.
I will try applying some heat to the nut next, then impact. I already sprayed a liberal amount of fluid film on it yesterday. Also, I was using an impact gun and that's what got the other 5 out, but it is just a 3/8" milwaukee battery operated unit I had in the field, so not a whole lot of oomph. I'm leery about a big breaker bar also because that nut is pretty narrow and I can tell the socket wants to slip off, so I have to hold it with one hand. Would be easier with a helper I guess. Is that a bad thing if the P/C turns instead?
Your comment about removing rockers and both boxes as a unit makes sense. I'll give that a go. Mostly I just wanted to find out which if any valves are stuck. Though the heads will most likely need to come off eventually also.
Also I ordered the engine service manual off amazon. sure would be nice if the old manuals were in the public domain and hosted online by now.
Tue, Feb 16, 2016 4:48 PM
danda
Reply to danda:
related question: besides the piston rings, what else might be rusted and preventing turning?
Here's my short list:
+ valves, stuck shut.
+ injection pump. ( doesn't seem likely, full of diesel. )
+ water pump.
what am i missing?
my plan is to soak first with marvel mystery oil for a few days. Then siphon it out, and replace with vinegar, which has a mild acid to remove the rust and is mainly water which is heavier than oil, so it should reach the metal past the marvel/diesel and even past any water still in there from the rain. might also try a little diet coca cola also as I hear good things about the phosphoric acid. A final trick will be to siphon again and then pour in some boiling oil; the heat is supposed to expand the cylinder and let the oil seep in through cracks.
Tue, Feb 16, 2016 5:07 PM
wimmera farmer
Thank you received: 10
Reply to danda:
+ water pump.
what am i missing?
D318 does not have heads. It is one long heavy brute to manage on your own without lifting gear. Also needs a lot of care to refit as there are a lot of seperate sealing rings in the gasket to keep in place.
Chances are you will end up pulling the head to get it cleaned out properly. A lot of crud can fall into the innards via those pre combustion chamber holes. depends how clean he water space is. If it is a bit blocked up there will be a heap at the bottom of the liners and the bottom pilot motor passage behind no 6 will be very likely be completly blocked. Then you can pull the pilot motor to clean that all out. Believe me it can be a long journey.
good luck WF
Tue, Feb 16, 2016 5:30 PM
7upuller
Reply to wimmera farmer:
good luck WF
Hey Danda,
There has been discussion here about the miracle rust buster. An article posted stated 50-50 blend of Acetone-ATF mix was the best performer. I have been lucky unsticking a couple of motors with this mix. A few not so lucky. It separates after time so a long shelf life is not recommended. On the last stuck motor, I mixed one gallon of each together, then poured one gallon down the exhaust and one down the intake. Old Magnet has taught me that the best place to get movement on a motor is the ring gear. So I pulled the starter and put a 6' digging bar wedged on the gear. Rocked back and forth. After three hours of injecting the "Loose Juice", I had the engine running. Others have taken a week or so of soaking. Good luck.
Glen
Tue, Feb 16, 2016 8:07 PM
9This process of getting one going is a slippery slope! Before you know it you will be doing a complete overhaul!
I was about to suggest that you would want to go ahead and break the precombustion chambers loose while the head is still on the engine as that can take some serious torque. But on the other hand if they aren't leaking I would probably leave well enough alone. If the head needs milling later, they will have to come out, but probably best to try to rattle them out with a good impact gun. I have seen them take the threads out of the head.
Really the only thing that will be holding the engine is the rings. I think you are going about it right. You may wind up overhauling it in the end, but that process is much easier if the engine will turn over.
I would delay taking the rocker boxes off until you know you are going to take the head off. I would just pour motor oil over the rockers and down the pushrods to lube the lifters and camshaft. Then if you want to check the valves simply bump on each rocker with a hammer handle etc.
Tue, Feb 16, 2016 10:27 PM
Hillbillybjopkr
Send a private message to Hillbillybjopkr
I agree that prying on the flywheel is better than the crank bolt.....your getting way more leverage that way......when I was working on the track adjusters on my D4...I used a combination of WD-40, PB-Blaster and Marvels....plus heat....I admit that I do swear by Marvels lol......reading previous post gave me a idea...what about boiling or really hot marvels.....then yes...digging bar on the flywheel and rock it back and forth.....if you can get a little bit of movement...you got it beat....just a matter of working it free from there
Wed, Feb 17, 2016 7:08 AM
