D69u extraction.
D69u extraction.
Showing 1 to 7 of 7 results
white halftrack
Send a private message to white halftrack
Saturday we were able to extract the d69u. It rolled with no issues and even with the lever being stiff the right steering clutch worked. Did not try the left. Loading was very uneventful. Short of pulling it is there any way of determining if the main engine is stuck? The pony is loose but I was told it was bad. I know not to assume. Can I engage pinion and turn pony by hand to turn over the main? Any help is appreciated.
Tue, Mar 1, 2016 10:49 AM
that's exactly what i did on one of my 9U's--I used a 2 1/4 inch socket on the pony flywheel
Tue, Mar 1, 2016 10:59 AM
white halftrack
Left track looks a little tight to me but should probably be run a while. I am missing the rock shields and a shield that mounts under the engine. I will do some checking but anyone close to Nebraska have a good pony for sale?
Tue, Mar 1, 2016 11:00 AM
kracked1
Reply to white halftrack:
Flip the compression release to start and the big engine should turn easy with the fan. Make sure the master clutch is disengaged also.
Tue, Mar 1, 2016 7:35 PM
Nice looking 9U!
I am probably just impatient, but with that farm tractor there, unless there was water in the oil, I would have had it spinning as it came off the trailer. Just have to remember the reverser lever is pushed Forward to go backwards and does not work in 5th ! Get it wrong and you get air breather oil on your shoes!
Good luck and please keep the updates coming!
Tue, Mar 1, 2016 8:06 PM
kracked1
Nice looking 9U!
I agree, if the main engine turns check all fluids and give it a pull start. Just roll for a bit with the compression release on till you see oil pressure.
Tue, Mar 1, 2016 8:36 PM
Thank you received: 62
Reply to kracked1:
They can be hard to turn with the fan if belt is loose or pulley warn. The crankshaft is not to hard to get to if no front pump or cable unit. A socket with long extension.
Can also be turned in the clutch compartment on the dry clutch,if it turns grease the 3 fittings.The hard to see one in the fly wheel. So you need to turn engine to find it unless you are lucky and it is up to begin with. Wet clutch unit can be turned at the universal joint.
Tue, Mar 1, 2016 8:56 PM
white halftrack
Reply to Ray54:
Update. Using the information from here my father pulled the cover off of the clutch area and was able with a little difficulty and stiffness it turned. We are going to change the oil and filter. I am going to take the cover off of the fuel rail and spray down. It has not run in 15 years. Any thing else before fire up? Grease all. Fill with coolant.
The main clutch works and breaks over nicely.
Wed, Mar 2, 2016 6:28 AM
