D69U clutch output seal replacement
Larry in phelan
Send a private message to Larry in phelan
Hi Everyone, My D69u with a wet clutch had an oil leak at the output seal.I removed the u-joint assembly as per the book. When I attempted to remove the yoke it hits the transmission and will not lift out.Does the yoke press on to the smaller shaft that is coming out with it ? It appears to be two pieces. I cannot find anything in the books that I have that shows the seal replacement with everything together. Any help is appreciated. Thanks,Larry
Mon, Aug 13, 2012 1:15 AM
Thank you received: 50
The yoke shaft passes all the way through the clutch and will not come out without removing the clutch assembly, also requires removal of the oil pump before the assembly comes out.
Mon, Aug 13, 2012 2:05 AM
Larry in phelan
OM, I was afraid of that after looking at the parts book.I was hoping there was a trick out there somewhere. Thanks ,Larry
Mon, Aug 13, 2012 2:08 AM
