D69U #25064 valve setting
lady cat skinner
Send a private message to lady cat skinner
Hello gentlemen. We have just replaced head gaskets and are ready to adjust valve lash. Question is....what is the procedure for making the initial setting? Thanks.
Fri, Nov 3, 2017 9:02 AM
Thank you received: 39
Intake and exhaust clearance 0.010" hot 0.008" cold.
6-cyl, 1,5,3,6,2,4 firing order
Position #1 @ TDC
Adj Intake #1,2,4 Exh #1,3,5
Rotate 360 deg to #6 @ TDC
Adj Intake #3,5,6 Exh #2,4,6
Fri, Nov 3, 2017 9:15 AM
lady cat skinner
Position #1 @ TDC
Thank you OM...I knew you would have the answer I needed. We'll work on it tomorrow.
Fri, Nov 3, 2017 10:17 AM
