D68U Need info
D68U Need info
Showing 1 to 10 of 10 results
invisabledog
Send a private message to invisabledog
A friend of mine just purchased a D68u and needs some help. I'm trying to get him to join in the forum, but so far he's been to busy to spend much time online. He got all the manuals with the machine, but none have any illustrations or parts listings for the blade assy. He wants to rebush everything to do with the blade and possibly replace the trunions. I know this may be dependent on what hydraulics are installed. Where can he find info on what system is installed? I told him to look for part numbers or id tags on the blade ect... He wants to get the right parts manual or part numbers. The machine is a 1955 s/n D68U8786. Thanks.
Sun, Mar 11, 2012 12:30 AM
Thank you received: 16
Would really help if you can post the s/n of the blade....I can most likely tell what's needed from that as there are a few combinations.
Sun, Mar 11, 2012 12:52 AM
invisabledog
Thanks OM. He can't find the s/n on the blade. I'm supposed to meet him later today to look at the machine. I'll see if I can find it.
Sun, Mar 11, 2012 1:05 AM
Thank you received: 11
Reply to invisabledog:
Hi, Invisibledog.
If my memory serves me rightly, the serial # on those blades was usually in the top right corner, within about 1 foot of both the top and the right side. There was a stamped aluminum plate rivetted to the back face of the blade with the number also stamped into the back of the blade under the plate, in case the plate somehow went missing, possibly due to some past carelessness (???????????????).
Hope this helps.
Sun, Mar 11, 2012 1:29 AM
invisabledog
Hi, Invisibledog.
Hope this helps.
No sign of a s/n anywhere on the blade. It has been repainted several times, so the numbers may be filled with paint. If there was a tag it is long gone. I took some pics, with the owners camera, of the blade and some part numbers on some of the brackets. Hoping to id it that way. I'll post some pics as soon as he emails them to me.
Sun, Mar 11, 2012 5:53 PM
See if you can spot any numbers on the hydraulic cylinders, sometimes you can back in to id that way.
Sun, Mar 11, 2012 10:47 PM
invisabledog
I didn't see any numbers on the cylinders, but I did finally get some pics. Maybe these will help. If not I'll have to make a trip to the machine for another look to see if I can fine some numbers.
[attachment=12582]SAM_2672.JPG[/attachment][attachment=12581]SAM_2670.JPG[/attachment][attachment=12580]SAM_2668.JPG[/attachment]
Wed, Mar 14, 2012 5:13 PM
From what I can see you have the 15C5001-up blade s/n C-Frame which is a combination cable/hydraulic version (has cable pulley mounts) but the upper blade braces suggest the blade is from the 9E1-up blade s/n hydraulic only version.
Back to your original request, there are no bushings that are replaceable.
The trunnion mounting ball is the same as the D4, D5 & D6 along with the same bearing and cap. The usual fix for worn trunnion bearing is to torch off and weld on another cap rather than cut the whole thing out.
Wed, Mar 14, 2012 10:18 PM
invisabledog
[quote="Old Magnet"]From what I can see you have the 15C5001-up blade s/n C-Frame which is a combination cable/hydraulic version (has cable pulley mounts) but the upper blade braces suggest the blade is from the 9E1-up blade s/n hydraulic only version.
The trunnion mounting ball is the same as the D4, D5 & D6 along with the same bearing and cap. The usual fix for worn trunnion bearing is to torch off and weld on another cap rather than cut the whole thing out.[/quote]
Thanks OM. I'll pass the info on to the owner. He restores aircraft and makes replacement aircraft repair panels and is very particular about his stuff. I can see him making replaceable bushings and pins for it.
Wed, Mar 14, 2012 10:52 PM
wimmera farmer
That is one very tidy tractor for 1955 build
Unless there is slop in the hydraulic ram eyes the rest looks almost as new.
Tolerances are not the same as in aircraft. The tapered pins for adjusting blade angle need to slip in easily to save fighting with them when changing the angle especially if there is dirt stuck to the blade putting it out of balance.
Would like to find one as good as that.
cheers wimmera farmer
Thu, Mar 15, 2012 3:39 AM
Reply to wimmera farmer:
Yes, I'd have to agree, that's one very nice D6. I was so busy looking at the blade the rest didn't register....oil clutch to.
Thu, Mar 15, 2012 3:58 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
