d68u dry clutch
d68u dry clutch
rrcat
Send a private message to rrcat
I am a newbie to this forum have a d68u s/n 8u4880 (1951) my clutch took a dump looking for any help on locating a good drive plate and bearing, need clutch plates relined and misc. I know some guys replace dry to oil hoping someone had a good set sitting looking for a home. Want to thanks all you guys over the last week I have read every post on dry clutch on this forum. Thanks
Mon, Feb 25, 2013 6:59 PM
Old 3T lover
If you find an oil clutch for your tractor, you will also need the top shaft for the transmission.
Mon, Feb 25, 2013 9:40 PM
Thank you received: 12
Reply to Old 3T lover:
Florin Tractor has most if not all you need to rebuild a dry clutch at good prices.There phone and email are in the sticky on parts at the top of the page.Have fun standing on your head or have dirt fall in your face.
Ray
Mon, Feb 25, 2013 9:53 PM
Have several oil clutches and transmissions I will make you a good deal on one if you are interested in swapping it out.
Tue, Feb 26, 2013 12:54 AM
rrcat
Thanks guys. I was thinking of converting to oil clutch but putting back dry would be easier for now. Found parts I needed at Cat dealer and a salvage today. Having clutch segments installed at a clutch shop. My main concern was the drive plate mine has some grooves from rivets but I was told it would work as it is. Drive plate bearing and bushing hadn't been greased in a long time it was shot. Thanks again.
Tue, Feb 26, 2013 9:20 AM
rrcat
Reply to rrcat:
My drive plate has 3 grooves each side aprox 1/16 to 1/8" deep can I fill with weld and have it machined down. would it be worth the effort? I bought this dozer several years ago was told it had a new clutch, they seen me coming. What little I used it I had to hold clutch lever back. I am learning getting a lot of info on this forum. Thanks
Tue, Feb 26, 2013 7:04 PM
