D6600 rod bearings
D6600 rod bearings
Showing 1 to 10 of 10 results
beaver-flat
Send a private message to beaver-flat
Does anybody have a source for D6600 rod bearings Cat # 3B7203?
My parts guy has struck out. I haven't checked with Cat yet though.
For a D6-2H s/n 2H7640
Sat, Jan 27, 2007 10:21 PM
beaver-flat
does the D8800 and D13000 use the same rod bearings?
Tue, Jan 30, 2007 2:14 AM
SJ
Send a private message to SJ
Yes they should be the same bearings.The rods are Std.3.625"crank specs.
Tue, Jan 30, 2007 4:02 AM
Reply to SJ:
The D8800 - 7M, 3T. 4T
And the D13000 - 1H6852-up, 8R, 2U, 13A
All are using current rod bearing # 2M6499
I don't have any info other than Cat original part numbers prior to these models or for the D6600.
Hope that's some help.
Tue, Jan 30, 2007 8:59 AM
KidNV
Send a private message to KidNV
OM, 2M6499 is $10.78 at regal, cat is $$74.72, they have them. They show the 3B7203 shows as invalid#, so there is a newer pn..
Wed, Jan 31, 2007 2:12 PM
SJ
I remember while I was working yet that a good bit of Cat rod & main bearings were made by Federal Mogul & were stamped right on them as such.
Wed, Jan 31, 2007 7:38 PM
beaver-flat
any idea of what the updated pn for 3B7203 would be? I'll try CAT tomorrow, too late today
Thu, Feb 1, 2007 5:15 AM
beaver-flat
Reply to beaver-flat:
Well, near as I can come up with is 2F2343 as the latest number for the bearings.....discontinued ๐Ÿ˜ž
took the number off the rod, witch updated to a 5B1294 with rod bearings 6B6483 and 6B6484 witch updated to 2F2343, another dead-end๐Ÿ˜
contacted the ram site about re-babbiting the old shells
Thu, Feb 1, 2007 7:35 AM
beaver-flat
ROD BEARINGS FOUND!!!!!!! ๐Ÿ˜„
I'll post the aftermarket number when I receive them.
Thu, Feb 1, 2007 11:42 PM
OzDozer
beaver-flat .. I trust you checked your crankshaft dimensions, to see whether it has an "early" or "later" size crankshaft.
New crank journal dimensions are 3.500" - 3.499" for "early engine" mains .. and 3.250" - 3.249" for "early engine" con rod journals.
"Later engine" dimensions for the 5ยพ" bore engine crankshaft, are .. 3.750" - 3.749" for mains, and 3.625" - 3.624" for con rods.
Fri, Feb 2, 2007 8:04 AM
beaver-flat
Reply to OzDozer:
Yes, it is the early/smaller dia crank. I believe the later/larger dia bearings are readily available.
Fri, Feb 2, 2007 9:31 PM
