D64r pony motor head torques???
denjoe
Send a private message to denjoe
Can anyone tell me what the torques are for the head on this pony? I don't have the manual. Had to replace a valve. Also torque on manifold assembly cover (the top plate on the pony) Thanks!
Fri, May 9, 2008 6:07 PM
SJ
Send a private message to SJ
As far as I know I don,t think they list it for them so just go by a nominal torque sheet for it. If you don,t have a sheet usually hardware stores have them or post the size of the studs and we,ll come back with it.I have rebuilt dozen of the starting engines on Cats & just tightened them up till they were good and tight.After doing so many you know when things are tight but not over too much so you strip the threads.
Fri, May 9, 2008 6:37 PM
denjoe
Reply to SJ:
Makes sense. Not a lot of compression there. Thanks SJ!
Sat, May 10, 2008 5:49 PM
Earlcoate Charity Open Day
