D6100 bearing clearances information requested
Thank you received: 24
Hi folks, we've received a request for D6100 bearing clearances information, or ideally the entire service reference if it's available. Could anyone help out?
Fri, Jun 28, 2024 1:09 AM
Thank you received: 20
That would be for the 5-1/4" bore 3-cylinder....
 [attachment=76957]Crankshaft sizes.jpg[/attachment]
Fri, Jun 28, 2024 2:08 AM
Many thanks. Which document is this from? And would it also have the torque specifications for the main and rod bolts/ nuts please?
Fri, Jun 28, 2024 5:10 AM
There is some more info on bearings and thrust in the "Servicemen's Reference Book for Caterpillar Diesel Engines" Form #5060B but I could not find nor do I have specs for bolt torquing.
Fri, Jun 28, 2024 5:58 AM
Thanks for checking anyway. I've forwarded on to the fellow the generic torquing figures plus those for the D13000 and other 5 3/4" bore engines as a likely upper limit
Fri, Jun 28, 2024 9:46 AM
