D6 , who knows more about it ?
johan7
Found this D6 recently . According to the owner It should have come to the Netherlands by Canadian liberators in WW2 . Later it was used for ploughing and a previous owner had simply lengthened the track shoes
There are no tags , no punched numbers and no numeralcod system . Who can tell more about this machine ? Thanks , johan7 .[attachment=31943]006.jpg[/attachment][attachment=31942]005.jpg[/attachment][attachment=31941]004.jpg[/attachment]
Thu, Nov 5, 2015 10:33 PM
That's a 4Rxxxx model D6 with the D4600 engine.
It would be a s/n 4R2266-up after they changed to the large rear hub.
Be a 1945-47 model.
Fri, Nov 6, 2015 12:01 AM
ag-mike
Be a 1945-47 model.
did u check the edge of the engine block for stamped numbers?
http://www.acmoc.org/bb/showthread.php?23474-Serial-numbers-on-the-edge-of-block
Fri, Nov 6, 2015 12:19 AM
Canuckd2
Send a private message to Canuckd2
Reply to ag-mike:
Looks like someone ground the paint off where the Serial # should be on the engine
Fri, Nov 6, 2015 1:04 AM
Thank you received: 77
Reply to Canuckd2:
There's a post somewhere on here how to use a fluid to raise the numbers from the block, even if they've been ground (enough to not be visible but no more) - I believe that it's a Cat instruction.
Fri, Nov 6, 2015 1:16 AM
