D6 Under-Powered
D6 Under-Powered
Showing 1 to 10 of 132 results
mtgstuber
Send a private message to mtgstuber
I need some help diagnosing a problem with my D-6. If I put it in 5th gear, the engine roars to life with plenty of power, but if I put it in 1st, and start up a steep grade, it struggles. That surge of power that the engine puts out when I put it in 5th just isn't there when I'm going up a hill in 1st.
Any thoughts? Would this be caused by the governor? Any notion why the governor would behave correctly in 5th, but not deal with the load in 1st?
Michael Garrison Stuber
D6U, #12 Grader, 2 Alpacas, 4 goats, 3 barn cats, a black Russian Terrier, and lots of trees.
Tue, Sep 8, 2009 9:49 AM
7upuller
Mtgstuber,
On my D6-9u I was working it pretty hard pulling a scraper, and it too was running out of power in first. When I would get a load , and hit the haul road in 5th, it pulled fine. I changed the fuel filters, and air filters, and it runs great now.-glen
Tue, Sep 8, 2009 10:10 AM
mtgstuber
Reply to 7upuller:
Mtgstuber,
Thanks 7upuller. Two things I'm trying to wrap my head around:
(1) Why do I get power in 5th, but not in 1st? If it's a filter problem, wouldn't I have an issue in 5th too?
(2) The service manual talks about the fuel pressure gauge dropping from good to normal to caution when the filters are clogged. I'm still reading green.
I've got replacement filters and gaskets, but I kind of hate to tear fuss with taking the hood off, cleaning everything, replacing the filters, and repriming the system if it doesn't need it.
My unit is 9U1417. It's already has new oil filters and I tore down and cleaned the air cleaner about 20 hours ago.
Thoughts?
Mon, Sep 14, 2009 2:08 AM
7upuller
Reply to mtgstuber:
Thoughts?
Mtgstuber,
I would still change the fuel filters if you are having a loss of power. Dirty fuel filters will keep a machine or truck running on average pulls. When grunting the engine on a hard pull is when they fail to supply enough fuel thus resulting lost power. It could be something else, but the first place to start is the filters.-glen
Mon, Sep 14, 2009 3:50 AM
Thank you received: 60
Reply to 7upuller:
Mtgstuber,
When was the last time you looked into or rebuilt the governor. Slow response to throttle and loading is a pretty good sign of governor issues.....assuming you are getting adequate fuel/air delivery. That's also a pretty early serial number, what's the condition and hours on the motor?
Mon, Sep 14, 2009 4:28 AM
mtgstuber
The hour meter reads 06538. Honestly, I'm not sure how to read it. It's unclear to me whether that means it has 653.8 hours on it, or 6538 hours.
I bought it about two years ago. I haven't changed the fuel filter, but I haven't run it much either -- probably put around 20 hours on it personally. I'm hunting around the house trying to find the notes from the previous owner as to what he did. To my knowledge, he had had it since '89. I know he didn't put a lot of hours on it either.
With respect to the condition of the motor, I confess I don't have enough experience to say one way or the other. It seems fine to me, but I may simply be clueless. Is there a good way to judge?
I don't believe the governor has been rebuilt anytime in the last 20 years.
Looking through the servicemen's reference it appears that the governor can be worked on in situ or it can be removed entirely for working on it on the bench. Any recommendations? Any thing I should know?
Mon, Sep 14, 2009 5:13 AM
mtgstuber
Reply to mtgstuber:
Oh! One other thing. Is the fuel shut-off valve a ball valve, such that I should be turning it 90 degrees? Mine has a square head, so it's somewhat ambiguous what position it wants to be in.
Mon, Sep 14, 2009 5:15 AM
7upuller
Reply to mtgstuber:
Yes ball valve. Turn 90
Mon, Sep 14, 2009 5:21 AM
Reply to 7upuller:
Technically it's a taper plug valve but works the same. Seeing as how there are fuel supply questions it might warrant looking at the valve a little closer. It has a square stem (usually chewed up) and some even have a direction arrow on the stem....also have seen the soft brass stem twisted so that indicated indexing can be off.
Overhauling the governor is best done on the bench.....all the parts are still available except the governor spring which is one of the critical pieces.
Recent rebuild cost for a D4 (same unit) about $500...you do the labor.
6538 hrs. is not a lot but these meters are not always reliable. Does the unit smoke? blowby out the crankcase breather? Use a lot of oil? Have good oil pressure?
If you are unfamiliar with engine assessment best bet would be to find someone that knows these old Cat's have a look at it.
Mon, Sep 14, 2009 7:19 AM
mtgstuber
It doesn't seem to eat oil. The exhaust out the stack is good and clean. There is a little bit of smoke out of the oil breather from time to time, but not much.
If the governor spring is a critical part, but not available, what do I do? Is it something that doesn't actually need to be replaced during a rebuild? Is there a source for them? Can it be cut down and reformed? (This is what I had to do for the spring on the pony motor to get the throttle working correctly).
Any experts out there that live near Spokane Washington?
Mon, Sep 14, 2009 8:07 AM
Reply to mtgstuber:
This is a specially calibrated spring meant to fit specific applications. Problem is that over time they tend to loose their calibration. There is not a lot of choice for replacement....either another used unit or live with the one you have (shown at the top of the picture). There are other parts that wear also (replaceable) like pins, rollers and bearings that develop flat spots that effect the operation.
Would also be a good idea to pull the fuel injection pump side cover and be sure the rack is moving freely, clean and well lubed. Units that sit a lot tend to rust and gum up and even get to the point where they freeze up.
Mon, Sep 14, 2009 8:50 AM
