D6 tracks
D6 tracks
Showing 1 to 9 of 9 results
Great southern land
Send a private message to Great southern land
Just a quick question. Would I be right in saying that d6d tracks won't fit my d6-5r
Fri, Sep 11, 2015 4:52 PM
Joel59
Send a private message to Joel59
Yes they are different pitch.
Fri, Sep 11, 2015 7:50 PM
rmyram
yes you would be correct, d65r tracks are not the same as the d6d tracks. major differences in pitch. if memory serves correctly, i believe the d65r had 6.75" pitch. i believe the closest replacement currently in use is the 6.91" pitch tracks on current machines.
Sat, Sep 12, 2015 1:02 AM
Joel59
Reply to rmyram:
Yes, I believe you are correct on this. 5r should interchange with the 9u which is 6.75" pitch. The 6.91" pitch is newer D5 stuff that is the common conversion for 9u's. I'm thinking of converting my 9u to 6.91".
D6d stuff is much bigger pitch, I'm sure someone can give specifics.
Sat, Sep 12, 2015 2:17 AM
m rust
Send a private message to m rust
Reply to Joel59:
I used d6 8u rails and pads on my d6 5r
Sat, Sep 12, 2015 6:47 AM
Reply to m rust:
D6D is 8.00 inch pitch.
Sat, Sep 12, 2015 7:07 AM
7upuller
Hey OldMagnet,
Do you remember what the undercarriage looked like on the D6-9u that I bought from TractorDon at one of his BBQ's? You were there that day! I remember him telling me that someone put the wrong tracks on and the pitch was off in timing. The pins were chewed up bad, sprockets too. It was the worst shape undercarriage on a Cat that I've ever seen. After switching over to the D5 tracks and sprockets, it's a great tractor now. Running the wrong pitch will destroy an undercarriage quickly. glen
Sat, Sep 12, 2015 10:30 PM
Reply to 7upuller:
Hey OldMagnet,
Yes, I recall. I kind of wondered how far you'd get with that miss match. Also recall the previous owner that Don purchased from didn't have a clue. Won't mention the sale price LOL.
Sat, Sep 12, 2015 10:48 PM
7upuller
Hey OldMagnet,
Now that it's got good tracks, and cleaned up a bit, it's a great Cat. The thing that got my attention on that tractor, was the factory installed glow plugs and electric start. It has all the correct manifolds and such from factory. Heck you know more about that stuff than I do. I averaged out the dollars. With the $100 Cat no. 60 scraper, and $75 #25 unit with coupler that Ed Akin let me out bid him on, the price range softened. :eyebrows:
Sat, Sep 12, 2015 11:00 PM
keloz
Send a private message to keloz
Reply to 7upuller:
Hey OldMagnet,
Hi Glen The 8u engine your friend (and mine) mr Oil Slick sold me is fitted with factory fitted glow plugs and starter, manifolds etc with air cleaner mounted over the left track not in the front of the operaters station.So different bonnet fire wall and the throtle is a5r style (not 8u 9u) style no aircleaner housing to mount it on. hey Mike still got it the throtle lol. kelvin
Sun, Sep 13, 2015 4:57 AM
