D6 Tracks
D6 Tracks
Showing 1 to 10 of 31 results
johnstone
Send a private message to johnstone
Can some of you Cat guys tell me what you think of the tracks in the pictures I have uploaded. I notice some of the links are not straight, like they are rusted in place....is this rust that will probably break free with more use? The sprocket has an odd wear, different angles of wear on the teeth......what caused this?
Anything else you can comment on about these tracks will be appreciated. I'm going to look at this tractor with the intent to buy it next week. Your imput will help me to make a better decision.
Thanks, John
1954 D47U, 1957 D69U, 1987 JD 950
Mon, Sep 3, 2012 6:33 AM
smocat35
Send a private message to smocat35
The undercarriage components which can be seen in your pictures are about as close to new as you can get. The pads, rails, sprockets, and top rollers look great. The front idler is a bad view angle, but it appears good judging from the height of the center. The angles near the tips of the sprocket are normal, this is how a new sprocket would look. There is one other component, the bottom rollers, take a look at them. The frozen links are caused by rust from sitting for prolonged periods. They will sometimes loosen up with use, worst case they have to be pressed apart and cleaned. Good luck.👍
Mon, Sep 3, 2012 8:52 AM
willitrun
Send a private message to willitrun
i have same deal with my 3t. haven't had much luck getting it freed up. i even jacked dozer up under frozen link with rail road jack and heated it up, no luck. maybe somebody has a better idea.
Mon, Sep 3, 2012 8:56 AM
josh
Thank you received: 14
Reply to willitrun:
If it were mine, I would try running the tractor in shallow water, lube up the rollers good and run it in water deep enough to cover the lower track section. a shallow gravel bottom creek would be just right.
Mon, Sep 3, 2012 9:19 AM
Reply to josh:
Take a look at the pin bushing wear also.
May be just the angle of the picture but that neareast sprocket root seems to show a thinner bottom section than the rest. Overall not bad except for the frozen links.
Got to thinking and checking a little more on those tracks. The D6 runs a 28 tooth sprocket and with the large front idler, a 40 link chain. This makes a non hunting tooth combination which means the same bushings run in the same sprocket teeth so there could well be a wear pattern developing from running those frozen links for some time.
Need to get the links fixed and jump a sprocket tooth to get a new wear pattern going.
Mon, Sep 3, 2012 9:25 AM
johnstone
I just got back from inspecting the D6, it is a 1957 9U model. As you guys said the chains look good. The rails measure just a hair under 4", the bushings have very little surface wear [I forgot to measure them]. The part number on the links is 2S5960...SEALED.
I took a better look at the sprocket and it has pretty even wear all around. Old Magnet noted one of the sprocket roots in the picture looked like it had a thinner bottom than the rest, to my untrained eye they all look on the thin side. Even though the sprocket seemed to have relatively even wear, I took notice that from running it today [I ran it about 200 to 300 yards] only every other root looked polished. I counted and the sprocket has 28 teeth and there are 40 links as Old Magnet said. So if the same bushings run in the same sprocket root, how do you get even wear on the sprocket and chain? Old Magnet, How would I jump a tooth to get a new pattern? Do those frozen links affect the wear pattern?
Thanks, John
Sun, Sep 9, 2012 12:05 AM
Reply to johnstone:
Thanks, John
Yes, if left uncorrected those frozen links will affect the wear pattern.
Jumping a tooth involves splitting the track and either rotate the sprocket to the next tooth or moving the tracks to do the same. That's the nature of non-hunting tooth track and sprocket combinations.
Sun, Sep 9, 2012 3:44 AM
A friend of mine has been pouring Diesel Fuel on a set of tracks for 2 years , then beating them free with a sledge hammer. I said, "Fellows claim water works better". He gave up on the Diesel Fuel, only going out to beat on them when it rained. Where he is at been raining alot. Anyways he called to tell me they freed up!
Don't understand it all but water really does work(at least for him)!
Sun, Sep 9, 2012 6:53 PM
catsilver
Reply to drujinin:
Those tracks have quite a bit of internal bush wear or 'stretch' that is why the idlers are well out and the wear pattern is high up the sprocket on the 'reverse drive' side, they are probably approaching 100% internal wear.
Sun, Sep 9, 2012 7:54 PM
johnstone
Reply to catsilver:
I made the owner of the D6 an offer this morning...we'll see what happens.
Catsilver, I agree that the idlers are way out and the internal wear is probably way up there, so why do the rails measure almost new?
I also have a question to OM"s comment, "That's the nature of non hunting tooth track and sprocket combinations". Why would Cat have this non hunting tooth track and sprocket combination? Especially in such a popular tractor as the D6 9U...Whats the reasoning? On the surface it seems counter productive when it comes to even wear of the sprockets and bushings. I must be missing something.
Thanks, John
Sun, Sep 9, 2012 10:50 PM
Reply to johnstone:
Thanks, John
Correction:
As Catsilver states , the length of the chain (link count) makes no difference. If the sprocket has an odd number of teeth, the number of effective teeth is fractional, and each tooth engages the chain only on every other revolution (hunting tooth). When the number of sprocket teeth is even only every other tooth is engaged so the sprocket periodically has to be moved one tooth (manually) to get wear distributed to all the teeth.
You could get back to a HT combination when replacing the sprocket and chain with the 6.91 in. pitch and27 tooth sprocket.
Get an actual measurement on your chains. With a stretched section (no frozen links) of 5-pins the length new is 26.98 in. and at 100% worn 27.46 in.
Also on that "water soak" thing I have never heard of this working on "sealed" track although it must be possible to get some moisture in there to have them rust up.
Sun, Sep 9, 2012 11:42 PM
