Try searching the BB for posts by "yellercat" as well. I believe that is where the pictures I posted came from. Those seal retainers are aluminum so go easy on the drilling and thread engagement.
As I recall when I did this, the 'pins' that you have to drill out are not very long - with a sharp drill, you won't have to drill very long until you are through them. Once the type of metal changes, it would be best to stop, or there'll be an extra hole in the retainers....
The retainers themselves were a real bear to get out. They fought me every step of the way - it took lots of penetrating oil and sweat to get them out. You need the threaded rod, like in the pic, and you also need a nut, as the retainer has MALE threads. I had to grind the 'corners' off of the nut to make it fit down the hole, and the nut has to be welded fast to the rod to keep it from spinning......
So, all you need - the treaded rod, a few nuts, and a couple flat washers. And that's the tool....
Rodney
