D6 pinion brake
D6 pinion brake
m rust
Send a private message to m rust
Is there a adjustment on the pinion brake on a D6 5r? If there is how would i go about doing it?
Tue, Apr 30, 2019 6:55 PM
gemdozer
Thank you received: 25
There is no adjustement brake pinion you could use ATF oil in cluch housing and if it is't working you need to change the brake discs in cluch housing
Wed, May 1, 2019 1:17 AM
Toby (Sasquatch on here) has a video on disassembly and tune up of the pony pinion clutch and brake.
Like Hector said, I have found that draining the old oil and refilling with any brand of ATF will make braking the pinion and engaging the gear without grinding a LOT easier! The thinner fluid causes less drag between the disks of the disengaged clutch and it's just not as slick as a motor oil, which helps the brake work better. Finally, you probably won't need to run the clutch adjusted as tight. I find that any discernable "snap" when your engaging the clutch is tight enough and it will turn the main engine just fine.
Wed, May 1, 2019 4:29 AM
m rust
Thanks. I drained and refilled with Atf. Now just need a warmer day without rain to try it out.
Wed, May 1, 2019 6:15 AM
