Is it out side? It may have I ce in it and around the pickup tube.
Are you sure you got all the bolts?
There are:
30 -7/16 x 1-1/8 pan bolts
4- 1/2 x 1-1/2 bell housing bolts
7- 3/8 x 1-3/4 bolts into the timing cover
With all these out it's a clear drop but you have to drop or remove the equalizer spring bracket to get it out.
Thanks for the reply! It is inside in the heat! Do all of the bolts that screw into the timing cover come up from the bottom?
Yes, all from the bottom.
Are you sure on the year model??? the earlier D4600 "R" series tractors have some "juggle" requirements to get the pan off.
serial # is 9U10453. I was told its was a 1952. Is that right? I will check the bolts again in the morning. This thing just will not break loose! Thanks
Year and model is correct.
Pull the side covers off and have a look in there to see if anything is hanging it up. I'm stumped😕 😕
Are all the bolts accounted for??
