d6 loader
d6 loader
Showing 1 to 6 of 6 results
rotorbob
Send a private message to rotorbob
I am looking at a D6 loader,the serial number is 10A86. Any info will help. Thanks Bob
Fri, Nov 13, 2015 2:13 AM
oldtanker
Send a private message to oldtanker
If you do not know how to evaluate the tractor, most important the undercarriage, then you will be better off taking someone else with you to look it over. Even if you have to pay for someone to come out. Most likely be far cheaper to pay someone to than it would be to buy something only to find that it needs new pins and bushings or chains.
Rick
Fri, Nov 13, 2015 3:52 AM
Thank you received: 77
Reply to oldtanker:
Rick
Hi rotorbob,
a list of things to start with are:
- check wear on the undercarriage: main points are pins and bushes, sprocket, idlers and rollers. For this, there is a tool (track gauge) that can be used to determine the amount of wear. There's also track frame alignment which can be checked if the machine can be moved
- does the engine run, does the machine move in all gears and steer as expected, and all controls/components work as expected including controls like the clutch/brakes and also the loader components
- leaks and/or broken items, worn/loose items, strange sounds/knocks etc.
As oldtanker wrote, a second pair of (experienced) eyes is always good, particularly if that pair of eyes can check things while you run the machine.
Fri, Nov 13, 2015 6:00 AM
Hi rotorbob,
On it!!! tomorrow AM:
Fri, Nov 13, 2015 6:44 AM
Hi rotorbob, it just occurred to me that you might have been asking for more in-depth things than the basics so please ignore my "sage" advice if that's the case : )
Fri, Nov 13, 2015 7:39 AM
Oil Slick
Post some pics and you'll get more thoughts on it.
Fri, Nov 13, 2015 8:41 AM
catfan
Send a private message to catfan
Reply to Oil Slick:
That is a No. 6 shovel built in 1953. They are a hoot to operate and will keep your hands and feet busy when loading trucks. They are not not a hoot work on.
Sun, Nov 15, 2015 10:28 AM
