D6 b gearbox
D6 b gearbox
Stuss
Send a private message to Stuss
Hi guys can someone help me, a fellow has a D6 B that has a crack in the gearbox housing that has been welded up couple of times but still leaks,
I have found a gearbox housing that looks okay but is out of a D6 C. casting no is 5M7327, The serial no is 5M7350,
Will this housing fit into the D6 B ?
Tue, Nov 12, 2013 6:44 PM
Thank you received: 19
I'd say no. The D6B trans case is a 4M7428 with no interchange indicated.
Also comparing a few internal bearing units with the 74A D6C, they do not interchange.
Tue, Nov 12, 2013 11:47 PM
rmyram
I've never seen a direct drive d6c so I can't tell on that, but I have seen d6b's that only had the tranny and finals stil attached to the frame rails and the transmission looked very similar to the ones used in a 9u.
Wed, Nov 13, 2013 10:45 AM
Reply to rmyram:
May look similar but there is no interchange there either.
9U trans case is a 1F4444 RPB 3S2044.
9U has a 12T pinion. D6B has 11T. Pinion end bearings are not the same.
There are other differences although some internal parts do interchange.
Wed, Nov 13, 2013 1:21 PM
Stuss
Thanks guys sounds like its not going to fit , so there is a housing here if anybody needs one and mate will still be looking for a housing or a complete box.
Thanks again
Wed, Nov 13, 2013 1:57 PM
