D6 9U water pump parts
22rimfire
Send a private message to 22rimfire
I have 56 model D6 9U and the water pump just starting leaking.
I pulled it a part to change the seal and I found that the bearings were gone.
Does anyone have the part numbers for the bearings and such?
I already have the main seal and another impeller.
Thank for any help!
1956 D6 9U
Sun, Dec 14, 2014 1:54 AM
Mike Meyer
Thank you received: 6
The bearings are both 1B4115, oil seal is 7B2174.
Regards
Mike
Sun, Dec 14, 2014 3:08 AM
Thank you received: 43
Note in my parts book seal and gasket group 2H5106.I have bought the group from Regal as well as Cat.I have used this on a 7xxx and 23xxx serial numbers so it fits most.The bearing no. is 1B4115 need 2.Check with supplier I am thinking I got a rebuild group that had everything but impeller.
Sun, Dec 14, 2014 3:22 AM
22rimfire
Reply to Ray54:
Thanks very much!
1956 D6 9U
Sun, Dec 14, 2014 3:31 AM
Thank you received: 39
Reply to 22rimfire:
Thanks very much!
Be aware that in 1956 (s/n 9U21301-24049)a change was made from keyed impeller to no key even though the shaft and impeller part numbers stay the same.
Sun, Dec 14, 2014 5:00 AM
