D6 9U Transmission ??
Showing 1 to 7 of 7 results
7mileranch
Send a private message to 7mileranch
Can the front compartment on the transmission be drained separately from the back, and winch. Just changed the oil, noticed some crud in the bottom of the front compartment. Would probably come out if the oil was hot. Thanks for the help
Mon, Feb 16, 2015 11:23 PM
Well, yes and no.
The transmission and steering clutch case each have their own drain plug but at some level the two compartments are tied together to be read by the one dip stick. The winch is separate.
Tue, Feb 17, 2015 1:49 AM
7mileranch
Well, yes and no.
My winch manual is saying it fills up with the final drives and transmission
Tue, Feb 17, 2015 2:17 AM
Reply to 7mileranch:
If this is for the #25 rear double drum winch s/n 9D501-up the winch is separate with its own fill check plug and drain plug and unit is to be filled by removing the breather. What manual are you looking at?
There are variations of fill and level check methods but all are separate. Post your s/n.
Tue, Feb 17, 2015 2:56 AM
Its got a Hydraulic Blade, so CCU is out must be a D6N Winch.
Tue, Feb 17, 2015 5:47 AM
Reply to drujinin:
I looked up the lubrication requirements in the D6N Hyster Winch manual and it does imply the oil in the transmission case and final drive compartment is shared but that pertains to the winch itself.
Filling the winch takes about 3-1/2 gallons of oil. The tractor transmission takes 10-1/2 gallons and the tractor final drives do not share that oil.
Also if you check, the winch drive shaft is sealed from the tractor transmission and bevel gear compartment.
Hope you haven't been running the winch dry!!! as it runs constantly as long as the main clutch is engaged.
Tue, Feb 17, 2015 7:27 AM
7mileranch
Oil levels were good. Oil wasn't. Changed all the oils. Wow was there lots of them. Fixed right brake fork(stripped), new clutch brake and a couple rollers. Thanks to some help from people here. Thanks for the help
Tue, Feb 17, 2015 8:53 AM
7mileranch
[quote="Old Magnet"]I looked up the lubrication requirements in the D6N Hyster Winch manual and it does imply the oil in the transmission case and final drive compartment is shared but that pertains to the winch itself.
Hope you haven't been running the winch dry!!! as it runs constantly as long as the main clutch is engaged.[/quote]
Found the filler plug, used the level plug as well. Thanks
Tue, Feb 17, 2015 8:54 AM
