D6 9U starting issue after rebuild
markpa13
Send a private message to markpa13
Once again, I come to you guys for your expertise. Just put together a D69U. New pistons, rings, sleeves, seals/gaskets, and valve job. I removed the pony and added a 24 volt starter. It cranks great, tons of white smoke, but no start! If I shoot a little ether on the air cleaner, I can get a chug. I'm assuming this is a compression issue. With new rings and the head being redone, I'm not quite sure where to look. The valve clearance is set to .010 inch. A couple of the fuel lines don't seem to seal good. They are tight as can be, but I still see a little seepage around the injectors. Could this possibly be the problem? Thanks in advance for the advice!
Sat, Dec 1, 2012 12:08 AM
Thank you received: 19
Are you sure you're getting fuel....takes a good yank on the throttle to get it to open past detent. Next would be to take the side cover off the fuel injection pump and check to see your getting full throttle rack movement and no stuck lifters.
What is the fuel pressure reading when cranking?
Have you run through a complete bleeding process to get air out of the system?
Line leaks need to get fixed but that is probably not the root of your problem. Check for split ferrules on the ends of the fuel lines. No amount of tightening will fix that.
Sat, Dec 1, 2012 12:38 AM
Inter674
I guess you have checked the timing to make sure it is not 360 degrees out? Perhaps not an issue in your case though if you have not had the crank out.
Sat, Dec 1, 2012 2:11 AM
Since you have electric start, you may need to use air pressure in the fuel tank to get the fuel system bled out completely. A small piece of an old tire inner tube which has the valve stem in the center of it can be clamped over the fuel tank filller opening with a large hose clamp. Apply air pressure until it bulges out tight and then go through cracking bleed screws and work your way to the injection pumps or the fuel lines at the injectors if you don' thave one of the little tools to reach in behind the lines and bleed the pumps. Once you get clear fuel there, go for a start. If it's cold, you may need quite a spray of ether. I would use about 2 seconds worth into the oil bath air filter.
You can also pull it to start it. If you need, you can pull backwards in 4th gear, but not in 5th. Fifth gear is forward only, no matter which way you put the reverser. Remember, the reverser goes forward to travel backwards, and back to travel forwards. Get it wrong and you'll get oil on your pants and shoes from the air filter.
Sat, Dec 1, 2012 3:37 AM
markpa13
Thanks for all the advice. After 6 months of rebuilding, I got her to fire up today. The air pressure to the tank using an old inner tube was a great little trick. I got all the lines bled and it managed to fire. Unfortunately, it was running a little rough, so I still got to play with the injectors and fuel lines to get it right. A couple lines from the pump to the injectors seem loose no matter how tight you make them. They started spraying fuel after a few minutes of running, so I'm guess those lines need replaced. I'll have to post some pics once she is 100%. Thanks again!
Mon, Dec 3, 2012 8:23 AM
Reply to markpa13:
Yes you'll have to replace those lines and do NOT overtighten them. The injection pump lifter setting should be checked also if running rough.
Mon, Dec 3, 2012 9:32 AM
Earlcoate Charity Open Day
