d6 9u sprocket rim replacement
rmyram
I was wondering if anyone had the instructions to replace the d6 9u sprocket rim? Specifically I am looking for the instructions to cut the old rim off and weld the new rim on to the spoked sprocket. the sprockets are currently removed from the machine. I searched the technical archives and found the d7/d8 instructions. If anyone could post up the D6 ones I would sure appreciate it.
thanks in advance.
Roger
Thu, Mar 26, 2015 7:24 AM
Just search the regular forum? I am thinking that a Thread had been ran on this subject? If not a D6, maybe it was a D4?
Thu, Mar 26, 2015 9:28 AM
Thank you received: 93
Reply to drujinin:
here is what I have and used when Mike Meyer and I replaced his RD6 sprocket rims on machine.
Hope this helps.
Thu, Mar 26, 2015 9:55 AM
Joel59
Send a private message to Joel59
[quote="rmyram"]I was wondering if anyone had the instructions to replace the d6 9u sprocket rim? Specifically I am looking for the instructions to cut the old rim off and weld the new rim on to the spoked sprocket. the sprockets are currently removed from the machine. I searched the technical archives and found the d7/d8 instructions. If anyone could post up the D6 ones I would sure appreciate it.
thanks in advance.
Roger[/quote]
I did this on a 9u not long ago. If I can provide any insight, let me know. Joel
Thu, Mar 26, 2015 7:10 PM
rmyram
thanks for the offer Joel, I currently have the sprockets off the machine so i will follow the instructions that were kindly posted by Mr Bedwell.
Would one of the administrators be able to transfer EDBs post to the technical archive?
Thu, Mar 26, 2015 10:16 PM
