D6 9U Radiator
D6 9U Radiator
Showing 1 to 6 of 6 results
7mileranch
Send a private message to 7mileranch
Is there a product I can put in the rad to open up better circulation in the system
Mon, Apr 20, 2015 10:21 AM
Try Cat for their radiator flush products but there is no substitute for rodding out a clogged radiator.
Mon, Apr 20, 2015 1:31 PM
Thank you received: 62
I used one of the Cat products and it didn't do near as much as I hoped it would.Shortly after this it started leaking around the upper o-rings on the pre combustion chambers.Cannot say they were cause and affect,but I am not inclined to us that type "fix" on my 9u's again.
It is a project to rod the radiator,but the only thing that is not shade tree mechanic friendly about it is broken bolts.I have not had any bolts that I could not remove by welding a flat washer and nut onto the broken part bolt.Many I had to weld several times but once it is all apart the pieces are not that heavy ,so lay them out weld let cool then remove or break weld and start over.I am not the greatest welder so as long as you can weld at all you can do it. I have done it a few,so it wasn't just that I got lucky with the first one. Good luck with which ever way you try.
Tue, Apr 21, 2015 9:34 PM
7mileranch
Reply to Ray54:
Thanks for the help guys.
Tue, Apr 21, 2015 10:48 PM
Reply to 7mileranch:
Common problem, flush out the crud and things start leaking.
Tue, Apr 21, 2015 11:54 PM
7mileranch
Maybe ill just leave it 3 hrs is lots out of the old girl.
Wed, Apr 22, 2015 2:10 AM
daron
To help prevent bolt breakage use a variable speed impact tool somewhat gently in both directions. I have a 1/2" Black and Decker battery one. Sure has helped me.
Daron
Wed, Apr 22, 2015 2:26 AM
