d6-9u pony rebuild
d6-9u pony rebuild
ncfarm
Send a private message to ncfarm
i think im having a brain f%^t. taking two ponys and trying to make one runner. dissambled them both the better rod bearings have FM 6 663 stamped on them. for what size crank journal is that for? the more worn set have 6b2298 on them which states that they are 0.020 under. my second question is what should a crank journal measure to match these rod bearings? i got a ruff mic of 1.844-1.845 on both crank journals, with my spec book and math doesnt that put it needing 0.030 under bearings? havent got to the mains yet. still have to pull the flywheels. any way to get that done without a puller?thanks ty
Mon, Jan 29, 2018 8:45 PM
Sounds like you will want to reuse the Federal bearings. Unless you have a good micrometer and confidence in using it, I would get a strip of plastigage and use it to check clearances of the bearing/crankshaft combination you choose. I agree the rough measurements look like you want 0.030" undersize bearings for 1.875 standard crankshaft journal.
I have a "steering wheel" type puller i welded up out of a scrap of 1" plate with a chunk of 7/8" all thread rod and two nuts. I just measure and drill or torch holes in the plate for each pulling job. If the required spread is just a little more or less than some existing holes, sometimes I trim the edges with a torch and use a couple flat washers on each pulling bolt. Other jobs require a new set. I have used it to pull several crankshaft pulleys off the diesels. I think the downsides of beating on the flywheel are too big for me to try anything short of a puller. The biggest one is that the front main bearing is only retained by a hollow pin which seems to fall out on its own fairly often. Certainly don't want to drive the shaft in or out of the block in an axial direction and damage that bearing and pin.
Mon, Jan 29, 2018 9:46 PM
ncfarm
thanks ccjersey
u can see alot of slop between the crank and rods when turn back and forth. is that much play needed for an oil splash system? u would think that 0.010 difference would beat and rattle the crank to pieces. suprisingly the one crank looks to be in pretty good shape.
Mon, Jan 29, 2018 11:23 PM
Thank you received: 33
Reply to ncfarm:
thanks ccjersey
Posting Standard pony engine specs.
If saved and printed out should be clearer.
Tue, Jan 30, 2018 8:45 AM
Thank you received: 62
Reply to edb:
Looks like you have 005 more to go before you even reach the acceptable limit, and probably up to another 005 after that with not much risk if your oil pressure and flow is good
Tue, Jan 30, 2018 8:49 AM
old-iron-habit
Don't use a jaw type puller on the outer rope groove. I have seen a number of them with notches broke out from where jaw pullers had broke them in the past.
Tue, Jan 30, 2018 9:47 AM
TOGNOT
Reply to old-iron-habit:
I had a pony flywheel that would not budge. Tried heat, even cussed at it. A lot.
Made a puller from two long bolts and a piece of 1" thick plate. Plate was about 6" long, 2" wide. Drilled 2 holes in the plate to match the flywheel holes , spaced the plate about 8 or 10" away from the flywheel with the long bolts going through the plate into the flywheel. Stuck a bottle Jack (small end) on the pony crank, big end against the plate.
I used a cheater bar and covered the whole thing with a heavy tarp, but it did pop loose.
Sound complicated but it's only 2 bolts and 1 plate ( and a bottle Jack)
Tue, Jan 30, 2018 1:00 PM
Thank you received: 50
Reply to TOGNOT:
Cats suggested method.....
Done with a small diameter hydraulic cylinder or jack even better.
Tue, Jan 30, 2018 1:41 PM
ncfarm
thanks for all the ideas. ill report back with progress and hopefully pics.
ty
Tue, Jan 30, 2018 6:51 PM
