D6 9u Pony Motor water pump.
Sthorpe
Send a private message to Sthorpe
Where can I get the correct parts to rebuild the pony motor water pump? Found an old post with the part numbers, but I’m not sure the part numbers are transferring correctly.
5f4339 seal 5f 4338 washer 4b 2667 gasket
Wed, Dec 3, 2025 1:57 AM
Thank you received: 140
Hi, Sthorpe.
The pony motor doesn't have a water pump. It relies on the diesel engine water pump circulating the water to cool it - which is why it is important to get the diesel turning over ASAP after starting the pony.
Wed, Dec 3, 2025 3:10 AM
josh
The seal assembly 4F0593 includes the seal 5F4339 and washer 5F4338, google it, available from several sources, try Cat for the gasket and maybe the seal assembly as well, if not, cut your own gasket.
https://gtengineparts.com/caterpillar/4f0593?srsltid=AfmBOop4TBJG3DgP9vlgSiQujb1hXyvEn81MITqAOFr_RhxNCWvqaGPR
https://www.ebay.com/itm/306588899774
Wed, Dec 3, 2025 3:22 AM
Sthorpe
Josh, Thank you!
Wed, Dec 3, 2025 3:35 AM
wimmera farmer
Thank you received: 10
Sorry Deas you have tripped up there, the D6 pilot motor does have a water pump. D2 D4 don't have a waterpump. You are allowed to be mistaken at least once in every ten years so don't feel bad cause you ain't. cheers WF
Wed, Dec 3, 2025 11:11 AM
Thank you received: 291
Reply to wimmera farmer:
WF: I casually mentioned how the D2/D4 don't have a waterpump, but rely on the main for circulation, but apparently he didn't read my post or wish to believe me. Hahahaha.
No further comment about your friend. LOL. Its all good. JM
Wed, Dec 3, 2025 3:15 PM
