D6 9U part help ?
D6 9U part help ?
Xtremist
Send a private message to Xtremist
Can anyone tell me what the part number is for this ferrule and the seal/gasket that goes over it ?  I thik ive found the ferrule in the book but im not seeing the gasket...  this is for an old 9U on the fuel pump.
thanks for the help !
Sun, Jun 12, 2022 2:00 PM
It takes an o-ring, 8B4967, the gasket between the filter housing and pump is 4F5148
Sun, Jun 12, 2022 6:35 PM
Xtremist
Where does the oring go...?  these are the old pieces that i have
[attachment=68066]book.jpg[/attachment][attachment=68067]ferrule gasket.jpg[/attachment][attachment=68068]ferrule.jpg[/attachment]
Sun, Jun 12, 2022 11:04 PM
Reply to Xtremist:
It goes around the ferrule, the old o-ring is flattened out. You need to replace the ferrule also. Just clamp a vise-grip on that old ferrule and use a small prybar to force it out.
Sun, Jun 12, 2022 11:07 PM
Xtremist
ok am i correct when i say that the ferrule is 2A3855 ?  your sure its an oring, it looks almost like a weird formed gasket, unless its just been in there for so long that its kind of set up like that now...
Sun, Jun 12, 2022 11:12 PM
Reply to Xtremist:
Yes thats it. Yes age flattens it out.
Sun, Jun 12, 2022 11:28 PM
Xtremist
really appreciate the help, thank you
Sun, Jun 12, 2022 11:37 PM
Reply to Xtremist:
Your welcome.
Mon, Jun 13, 2022 4:14 AM
Thank you received: 62
Your welcome.
I had been warned by many here that the o ring would not look like a o ring coming out. I had a local know it all for help he was good about remembering and had done some boring but exacting tasks such as putting new o ring between the many hydraulic control blocks on a Gleaner sidehill combine . He was not into the internet at all, so taking him inside to read the posts he still would not believe what looked more like a V packing ring from a old hydraulic cylinders could be fixed with a fat o ring. But he finally let me use it and all has been good for 10 years or so. If only he had worried about his own health as much because diabetes got him few years latter at 58.
Mon, Jun 13, 2022 5:49 AM
