D6 9U O Ring Between Fuel Filter Assembly and Fuel Injection Pump
First Cat
Send a private message to First Cat
I ordered a 6B4967 seal, a # which I found in my parts book which should go over the ferrule on the fuel filter housing and it doesn't look like the old one. Is this a O ring because that's what Cat sent me? The old one looked like it was a tapered rubber seal. Did I get the wrong #?
First Cat
Tue, Aug 28, 2018 7:53 AM
NOPE! Its Right!
They get squished in there to look like a different shape!
Go back 2 or 3 pages on here someone else was just doing the same thing (D4 maybe?)
Lot of good replies on how to get it back in there without damaging it.
Tue, Aug 28, 2018 8:29 AM
The recent discussion was about how to get the one on the governor end of the fuel gallery in place. There is a plug held on by a single bolt/stud with nut that closes off the rear of the fuel gallery (governor end) using the same o-ring as the one you are asking about. Later model pump housings were cast with the rear end blocked off so they do not need the rear plug and seal.
Tue, Aug 28, 2018 8:42 AM
