D6 9U Fuel Consumption?
D6JP
Send a private message to D6JP
Can someone please tell me what the average fuel consumption on a D6 9U should be.
Fri, Aug 7, 2009 3:26 AM
Thank you received: 43
Owning three 9u's pulling the same tillage equipment it vary some by how the fuel pump and governor is set as well as driving style.I am looking more at gallons per acre than gallons per hour,but with tillage work I would guess 4 gallons per hour is close.Having a hard nose with a 6s cat blade I would assume dozing would use a little less.
Fri, Aug 7, 2009 4:22 AM
bruce oz
Thank you received: 21
Reply to Ray54:
hello here is the nebraska test that show fuel consumption ,bruce oz
1955 d6 9u- http://digitalcommons.unl.edu/tractormuseumlit/1043/
1949 d6 9u -http://digitalcommons.unl.edu/tractormuseumlit/986/
Fri, Aug 7, 2009 4:39 AM
morseman
Send a private message to morseman
Reply to bruce oz:
I have 9U16163 which was new in 1954. I used it through 1967 pulling a #60 scraper. You had to keep filing all day to use 36 gal. plus/minus. She is old and tired, but still my favorite.
Fri, Aug 7, 2009 8:22 AM
