D6 9u electric conversion.
Showing 1 to 10 of 18 results
lghtspeed
Send a private message to lghtspeed
Last week my pony motor puked out. So after researching this and having a few extra 42mt starters lying around, I'm going to make it a direct electric. I found a page where oldmagnet detailed how to do it when the provision is not drilled like mine. Here is the fixture I made tonight to drill the holes in the bellhousing.
[attachment=30617]20150817_204419.jpg[/attachment]
Tue, Aug 18, 2015 8:26 AM
old-iron-habit
[quote="lghtspeed"]Last week my pony motor puked out. So after researching this and having a few extra 42mt starters lying around, I'm going to make it a direct electric. I found a page where oldmagnet detailed how to do it when the provision is not drilled like mine. Here is the fixture I made tonight to drill the holes in the bellhousing.
[/quote]
Nice looking fixture. Please post some action shots and let us know how it turns out.
Roger
Tue, Aug 18, 2015 8:34 PM
lghtspeed
Reply to old-iron-habit:
[/quote]
Roger
To check the accuracy of the data I made my fixture from, I took the fixture to a friend who has a spare d318 and his casting has the starter provision hole machined. The fixture was off about .1 vertically. So I cut it apart and manually aligned it and rewelded it on the spot. So much for the precise machining oriinally.
Now to take it to the dozer and get cutting.
Sat, Aug 22, 2015 10:17 PM
lghtspeed
Reply to lghtspeed:
Heading out to get to work on the project.
Mon, Aug 24, 2015 8:05 AM
lghtspeed
Reply to lghtspeed:
Mounted the bracket onto the dozer, it was a fuzz tight which is exactly what I wanted.[attachment=30719]20150822_135108[1].jpg[/attachment]
Drilled out the pilot hole for the main hole.[attachment=30716]20150822_135300.jpg[/attachment]
And after about an hour and a half of this (no this drill didnt do it, I used a half inch drive dewalt drill) [attachment=30717]20150822_140018.jpg[/attachment]
I got to this, notice in the lower right corner the hole appeared to be a fuzz low yet as it was into a casting boss[attachment=30718]20150823_100513.jpg[/attachment]
Mon, Aug 24, 2015 8:15 AM
Reply to lghtspeed:
Running in to the boss is not unusual, just take the die grinder to it enough to be sure the drive end housing clears. What size hole did you do, the 3-5/8" or 3-3/4"?
Stuff some insulation wool in the hole so you don't get grinding dust in there.
Mon, Aug 24, 2015 8:27 AM
lghtspeed
@oldmagnet, I used a 3 5/8 hole saw then used the die grinder to smooth out the boss. Something not shown in the pictures is the vacuum system for shavings and dust control [attachment=30720]20150823_104034.jpg[/attachment]
Then Checked to see that the alignment was good. I had about .010 gear clearance.[attachment=30721]20150823_104050.jpg[/attachment]
After I checked that I predrilled the 15/32 holes. I had to take off the cover to get the drill close enough to the engine.[attachment=30722]20150823_110321.jpg[/attachment]
In the next week Ill drill out the 5/8-11 taped holes to .531 and tap them, also I will be reassembling the starter and finishing any mods needed to it. I should be able to have it mounted this week if the rains hold out.
Mon, Aug 24, 2015 8:54 AM
Reply to lghtspeed:
Looks like all is going well. Tapping the inside hole is a tight operation.
Are you going to do the alteration to the lever housing so that the solenoid fits vertically. Need the correct drive end housing to match.
Some folks hang the solenoid upside down but Delco does not recommend that.
Mon, Aug 24, 2015 10:10 AM
lghtspeed
For the alternator I will modify a one wire to hook up where the original alternator was. As for the starter solinoid, I will mount the starter so it is up.
Mon, Aug 24, 2015 5:59 PM
bvandragt
Send a private message to bvandragt
Reply to lghtspeed:
I work in a machine shop and when something ends up being .100" off, it is because somebody used a .200" diameter edge finder to find an edge, zeroed their digital readout and forgot to travel .100" (half the edge finder diameter) and re-zero the DRO so the spindle is over the edge just picked up.
Brian
Mon, Aug 24, 2015 9:38 PM
Reply to bvandragt:
Brian
Now that I think about it, your 0.010" pinion to flywheel clearance seems a little tight. May find that the pinion binds when everything warms up and expands. I would like to see more like 0.020 - 0.025" clearance. I'm thinking your dropping the center 0.100" from the provided template dimensions is the reason the clearance is tight.
If your looking for some recovery you can offset grind the starter hole to gain more clearance. Be nice to do it before you tap the bolt holes but it can also be done if you've already tapped by enlarging the drive end housing mounting holes if necessary.
Appreciate your step by step procedure and pictures. It's rare that I get any feedback on how things go, which is a good thing I guess.
Mon, Aug 24, 2015 10:05 PM
