D6 9u controls
D6 9u controls
krazeekat
Send a private message to krazeekat
Looking for a quick run down of the controls on a d6 9u
It has power reverser I believe
Picking up the machine on tuesday.
Can anyone confirm that the machine weighs about 30k w/o blade?
Thanks.
Sun, Mar 30, 2008 8:30 AM
Congratulatons!
Check the serial number!
A D6 9U won't weigh that much without a blade, and it doesn't have a power reverser. Bare tractor is ~18,000# and it does have a reverser shifter, but it's strictly manual.
From left to right you have the main clutch, left steering clutch, right steering clutch, throttle up on air cleaner (pull it to speed up, push it to slow down), 5 speed stick, and finally on the right side you have the reverser, push it forward to reverse, pull back to go forward.
Reverser works in everything but 5th gear, either way you shift the reverser, you will still go forward in 5th. In 1-4, reverse speed is slightly faster than forward speed.
Sun, Mar 30, 2008 9:42 AM
