d6 9u brake adjustment info
Showing 1 to 7 of 7 results
2HIGHTEN
Send a private message to 2HIGHTEN
I have my D6 9U at home now and need information on how to adjust the power brakes. the tractor SS # 25350. Any help is appreciated.
Also looking for manuals for this tractor.
Wed, Nov 5, 2008 11:00 AM
I assume you mean the power boosted steering clutches....there are no power brakes.
There are actually two things to check.
If it is just the brake adjusting procedure you need let me know and I will post.
Wed, Nov 5, 2008 11:43 AM
2HIGHTEN
Ran the tractor for a couple hour today and the steering clutches seem fine , The right brake is also fine but I need to adj the left brake. Thanks for the help so far . Ron Meeder
Thu, Nov 6, 2008 6:21 AM
Reply to 2HIGHTEN:
Ok,
Brake adj. added.
Thu, Nov 6, 2008 8:24 AM
acjelks
Send a private message to acjelks
Ok,
Brake adj. added.
Hi,
I'm kinda new around here, I would like to see the brake adjustment procedure and anything you can tell me about troubleshooting a steering clutch booster. one side works, but the other doesn't.
Andy
Tue, Jul 26, 2016 9:38 AM
Reply to acjelks:
Hi,
Andy
First thing to check on the steering booster is that the levers fully retract. If they don't one side will affect the other.
Tue, Jul 26, 2016 11:44 AM
acjelks
Thanks, I'll dig into it as soon as the rain stops. Also, I apologize for not having a cool nickname.
Wed, Jul 27, 2016 3:00 AM
acjelks
Reply to acjelks:
I adjusted the free play per instructions, but the left side still did not work. I discovered that the left side would work if i pushed the right side forward. this led me to remove the floor plate where i discovered the jam nut on the push rod had backed off. I adjusted the push rod and tightened the jam nut and that cured it!
the next problem is going to be the stuck nut on the brake band adjustment. I was hoping i could adjust the brake without removing the tank, but it's not looking too good. I am soaking it in kroil and will try again in a day or two.
thanks again for the help
Andy
Sun, Jul 31, 2016 9:20 AM
