D6 9u
Ron A.
Send a private message to Ron A.
I have a D6 9U-Seriel #9U28590- that I have had for about 40 years. Recently I have found that the only gears that I can operate in are 1st and 2nd. The transmission shift lever won't move over to the 3rd/4th gear position. This doesn't bother me too much as 1st and 2nd are the only gears I use most of the time. I used to use 3rd sometimes when plowing snow. What has me concerned is that there might be some loose parts floating around down there that might get caught up in something and tear up the whole works. I haven't opened it up yet to look inside. Hoping to get some suggestions before I do. Has anyone experienced a similar situation and if so, have recommendations?
Ron A.
Sun, Sep 17, 2017 12:30 AM
Thank you received: 64
I'd first get the transmission side cover off and check the shift rails and detents.
Sun, Sep 17, 2017 12:45 AM
Yes, sounds like one of the "gates" is out of position or more likely the shift fork has come loose from the rail. Could be loose or just sliding on the shift rail so it will not move the gears.
Sun, Sep 17, 2017 1:38 AM
I was thinking more like one of the shift rail guides is stuck or frozen (lack of use) or one or more of the detents is stuck.
Sun, Sep 17, 2017 3:40 AM
Ron A.
OK. Thanks guys.
Ron A.
Sun, Sep 17, 2017 3:43 AM
Dozer Doug
Send a private message to Dozer Doug
Reply to Ron A.:
OK. Thanks guys.
Ron A.
I had the same problem. The shifter boot had cracked and had let rainwater into mechanism, over time causing shifter to freeze up, so that you could only shift first and second. Remove boot, and you will most likely see the problem. Heat and lots of loose juice. Easy fix.
Mon, Sep 18, 2017 12:33 AM
Thank you received: 62
Reply to Dozer Doug:
If doing what Doug says dose not fix it,the next place to look is the side cover and the detentes as OM was talking about.
Had one that jumped out of 1st gear,and a little loose juice and maybe a different spring fix it right up. At the time I was not hopeful about that little bit fixing it but that is all that it took.
Mon, Sep 18, 2017 4:48 AM
Ron A.
Reply to Ray54:
OK. Thanks guys. I think I'll start with the easy solution first. Then, if that doesn't work, go into more detail.
Ron A.
Mon, Sep 18, 2017 5:06 AM
Ron A.
Pete:
OK. Thanks.
Ron A.
Tue, Sep 19, 2017 10:28 AM
