D6 8U8453 right track jerks
Showing 1 to 10 of 24 results
KingLuxor
Send a private message to KingLuxor
Hi Folks,
I found this forum looking for information on my D6 8U.
Recently purchased from an individual with the description of having a final drive issue. If moving forward with both steering clutches engaged you would never know there is a problem,
however if you release the left clutch the right track jerks and movement basically stops. When the person I purchased from delivered it he had to drive in reverse to get it to the location it is parked at now and said that it seemed to pull just fine on both sides in reverse.
I am new to the associated terminology, but hopefully I have given enough description about the issue.
Looking over parts diagrams, if I am looking correctly it looks like the transmission has one set of drive gears, that is there isn't a set for left and another set for right. My thinking is that if the left track is being driving as expected, there would be little chance of the issue being in the transmission. With all the recent rain I have not gotten a chance to do anything to the it yet, there are a few obvious steps I will take before jumping right in to the final drive.
Drain oil and check for glitter or metal debris
Assuming I have access to do so, use my bore scope to look inside the final to inspect for damage
But before I even get this far, maybe something stands out from the description of the issue and someone may have advice ?
From my understanding this machine has 4 gears, without having operated it and verified the issue happens in all 4, but going back to my understanding which may be wrong, each steering clutch takes power off the transmission equally, or am I mistaken about this ?
Thank you,
James
Wed, Feb 15, 2023 1:54 AM
wimmera farmer
Thank you received: 10
Suggest you find servicmans reference book to study before you start dismanteling things. Usually available on ebay. Problem is after the transmission most likely in the bevel gear/ steering clutch comparment at the rear of the machine. Under the operators seat.Or in final drive case that entails track disconected. You are in for quite a job and some heavy lifting.
best of luck WF
Wed, Feb 15, 2023 4:23 AM
Reply to wimmera farmer:
best of luck WF
Definitely drain the oil from the right final drive and look for metal particles---each final drive takes power off the bevel gear shafts separately
Wed, Feb 15, 2023 4:46 AM
KingLuxor
best of luck WF
Thank you for the reply. I have books, the seller just forgot them when he delivered, so I am picking them up later. In the meantime what I have been able to find online was guiding me away from the transmission, I was just looking to confirm this in theory.
Looking at photos on ebay service manuals gives me a much better picture of possibilities.
Fortunately I have 20 years of experience working on 1940s era industrial machinery, just big gearboxes, clutches and valves. Certainly a different type of machine here, but not beyond of my capabilities.
For the sake of discussion could you or someone expand on the thought of not pulling with forward travel but seeming to pull fine in reverse. Would there be a specific reason that would happen from experience or is this just following the symptom to the most likely culprit ?
Thanks for reading and thank you for your time,
James
Wed, Feb 15, 2023 5:11 AM
Reply to KingLuxor:
James
I have had gears that would function in reverse but not forward---when i pulled the gear out i found that the foreword direction on the gear had rounded the gear teeth so they slipped
but in reverse the teeth were not so worn and worked---had a drawbridge once that would go up fine but kept skipping on the downward travel
Wed, Feb 15, 2023 5:38 AM
Thank you received: 78
Reply to dpendzic:
Hi James, your understanding in post 245488 is correct. I didn't see your question about the drivetrain answered and if it's not evident from the parts catalog, the engine driving through the clutch and through the transmission is typical but the difference to vehicles with steering wheels begins at what in them would be the differential. In this tractor, the "diff" has no differential action; it's just a bevel gear arrangement driving a shaft that extends out both sides of the bevel gear, much like axles on a car, so that shaft always turns as one. On each side of that shaft, there is a clutch, with a lever in front of the operator for each side's clutch. The operator pulls the lever and the clutch on that side disengages from driving the track on that side. To assist with sharp turns, each side also has an independent brake, so if pulling the clutch lever doesn't completely stop the track on that side, the operator can apply that side's brake to stop the track, enabling the tractor to essentially pivot on that side's track, making a sharp turn.
Wed, Feb 15, 2023 9:02 PM
Thank you received: 62
Don't get in to big a hurry to start taking things apart. From my reading, you have experience the problem yourself? I am thinking there could be several problems. I am thinking a slipping steering clutch and a track jumping off the rollers. What is the condition of undercarriage?
So when you try it out have someone along side watch what the track is doing.
No dumb questions. Also hard to guesstimate your knowledge, don't want to insult you by starting to basic. But the newbies have thought it was a major problem and it was only there lack of knowledge. With such simple things as using brake as well as just pulling the clutch to make a sharp turn. If you have patient people here can walk you through fixing about anything.
Wed, Feb 15, 2023 11:01 PM
8C 361
Thank you received: 12
[quote="KingLuxor post=245488 userid=17092"]Hi Folks,
Just a wild ass guess here. ...... I am suspecting excessive slop in the (bevel gear) cross shaft bearings.
While this condition can be easily checked  and verified  it can be  difficult and time consuming to repair.
You may be able to compensate for it and get it operational by a simple adjustment of the steering clutches. Try backing off on the free travel adjustments on the steering clutches.
Tom
 [/quote]
Thu, Feb 16, 2023 9:18 PM
gary in CA
Reply to 8C 361:
Tom
 [/quote]
I would suspect a broken cross shaft also known as bevel gear shaft
Thu, Feb 16, 2023 10:54 PM
17AFarmer
Reply to gary in CA:
I saw a 3T with the teeth on the outer clutch disks so wore out when you pulled the other clutch it stopped, new disks and a drum fixed it. D6s have 12 disks and don’t cause as much trouble, D7s have 10 and wear out quicker. 17afarmer
Fri, Feb 17, 2023 2:00 AM
Reply to 17AFarmer:
Yes, it is possible that worn teeth on the steering clutch discs and hub will allow movement in reverse but not forward.
Fri, Feb 17, 2023 2:04 AM
