D6 8U Resurrection
D6 8U Resurrection
Showing 1 to 10 of 13 results
johncat07
Send a private message to johncat07
g'day
just decided to show the old d6 8u i bought for clearing my block after cyclone yasi did a number on it. Yes the d6 is rough with a capital R, but essential now clearing on my d2 has evolved from somewhat dangerous to downright dangerous. The d6 has not started yet, it all turns over free and the magneto now has spark after a tweaking. the carby is the hold up as it floods the right hand cylinder, just a clean and it should be right. the main clutch is my worry as the inspection cover was left off for what seem's an eternity. Funny i've never had a clutch stuck disengaged. Will update, no restoration just resurrection to get the job done. oh and that isn't my shed![img]http://i1227.photobucket.com/albums/ee425/johncat07/02042011001.jpg[/img][img][IMG]http://i1227.photobucket.com/albums/ee425/johncat07/02042011.jpg[/img][img]http://i1227.photobucket.com/albums/ee425/johncat07/29052010001.jpg[/img][/IMG]
Sun, Apr 3, 2011 7:10 PM
Thank you received: 105
Hi, Johncat07.
My guess would be that the slide mechanism for the thrust bearing is stuck on the shaft and needs to be freed up. Some of Ol' Grump's 'loose juice' and a bit of gentle persuasion ought to do the trick.
Happy yunsticking. Hope it all works for you.
Sun, Apr 3, 2011 8:27 PM
ianoz
Hi Johncat07, Welcome to the forum , The D6 should be a handy tractor ,and certainly a bit safer with the canopy than the D2.Certainly is a nice shed ,pity it can't follow the D6 home with you .Ian .
Sun, Apr 3, 2011 8:36 PM
johncat07
Reply to ianoz:
well i managed to get the old girl going, quiet easily today. So glad i didn't have the same troubles that i had thursday, with a few never in a million years events, and alot of cursing.i had a longer vid but didn't save it. maybe tommorow i'll get a walkaround vid. oh and the main clutch was disengaged all these years but still managed to weld itself together with rust, same problem i had on d2.[video]http://www.youtube.com/watch?v=O2pj8ZjYzG0[/video]
Sat, Apr 9, 2011 5:34 PM
johncat07
Reply to johncat07:
the pony is giving me grief, dozer is outside now. reckon a d2 would push start a 6? what gear would be best?
Thu, Apr 21, 2011 10:29 AM
try 4th on the 6
make sure the reverser lever is forward for reverse and back for going forward
You can use the decompression lever to help get it spinning over.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Thu, Apr 21, 2011 8:03 PM
Fower VF
Send a private message to Fower VF
try 4th on the 6
I agree with ccj. you should be able to start the 6 easily by pushing it. advantage of having another dozer is that you can get to lift the blade a bit on the 6, reduce the drag and get some traction on the 2. We started our d7 for years by towing it backwards with the blade dragging, have even done it with a 2 wd drive tractor. Use of the decompression lever is essential to get it spinning over.
Cat D7 4T; Cat 951 A
Fowler VF crawler
Aveling Barford DX8 roller
Ransomes TS 69 hexatrac plough (2)
Ransomes mole plough
Fri, Apr 22, 2011 3:55 PM
ianoz
Reply to Fower VF:
Hi John , I was wondering how did you get on with the cleaning up with the D6 ?
Thu, Mar 29, 2012 8:57 PM
callan
Send a private message to callan
Reply to ianoz:
hi john,
I am up the road from you mate give us a call 0429 479 077 for a yarn. I have a couple of d4's.
if you havent met or know of joe camilleri I'll give you his number when on the phone.
He is a brilliant and very friendly cat mechanic up the palmerston.
mike if your reading this , i think i remember you saying that joe told you the d6's did not like being tow started as it was hard on the crankshafts, and that cat realeased a bulletin about this.
had anyone else heard of this ?
Fri, Mar 30, 2012 11:38 AM
callan
Reply to ianoz:
hi john,
Fri, Mar 30, 2012 11:57 AM
Mike Meyer
Thank you received: 6
Reply to callan:
hi john,
[quote="callan"]hi john,
had anyone else heard of this ?[/quote]
Hi John and Callan, Yes, that's what Joe told me, towing or push starting old Cats is a last resort deal because of the odd reverse strain placed on the crankshaft, he has seen more than his fair share of cracked cranks in his 55 years working on them as one of the best Bush Mechanics in Australia. I guess oil pressure wouldn't be in the green zone either in this situation, particularly if a Cat has been sitting out in the bush for a year or three not being driven, slowly filling with water, but hey, for every old Cat with a broken crank after push or pull starting, I'm sure there will be 10 folks chime in here now with stories of only push starting their old Cats for the past 40 years after the pilot motor crapped out!๐Ÿ˜†๐Ÿ˜†. When I go up to stay with Joe I'll be helping him work on the gearbox of a 8U I believe, after we finished splitting my D2 5U there and fitting new steering clutches, I told him I'll go on strike if he asks me to help fix anything other than Cats while I'm there, I'll leave the Fowlers, Internationals, Fiats and other makes to you schmarter boys!๐Ÿ˜†
regards
Mike
Fri, Mar 30, 2012 1:24 PM
| โ€œDe Domelaarโ€ Gebr .V.d. Heiden Domelaarsweg 3 7475 MARKELO Netherlands
