D6 8U Pony Motor Rebuild Discussion
Showing 1 to 10 of 19 results
Scoop
Send a private message to Scoop
Good Evening,
New to forum and may be a little clumsy here so please bear with me.
Gotta D6 8U-2042 Dozer been working on for a few years. Struggle to keep Pony running to fire up main engine. Been able to tweak just enough but kept getting worse. Finally decided to pull and tear down. Found Exhaust valves not seating good and lot of carbon buildup, intake valve with broken spring, rings worn (comp @ 0.065" gap), little pitting on one rod journal, main journals look good, main aluminum bearings scored a little bit, bottom water ports on heads clogged with heavy gunk, crank rod and main journals within tolerance as I measure, cylinders and pistons look good no scouring.
Plan is to have looked at this weekend by an old timer machine shop near me to make sure it is serviceable and then rebuild. Would like to keep an active feed going through the rebuild to let you know how it's going and to have some guidance.
Here's my problem right now, I'm a little uncertain about calling out the right part numbers. I see some great contacts in the Library, but before reaching out to them I'd like to bounce the problem off you guys to see if you can help.
I have the shop and parts manual that is spot on for the Crawler. The parts diagrams for the Pony look darn near perfect (minus one filter element on manifold assembly head for all 8U models, idk why), EXCEPT some of the major part numbers in the Manual/Book are slightly different than the ones stamped on the parts.
Here are the differences on Major Parts:
Manual/Book No. on Part
BLOCK ASSEMBLY IF3529 4F8395
COVER ASSEMBLY (REAR) 4F2204 4F2003
MANIFOLD ASSEMBLY 5F8254 5F8253
HEADS 4B2459 4B2458
GEAR (TIMING) 4B2330 4B2329
FLYWHEEL 5F8407 5F8406
ROD ASSEMBLY 7B4613 7B4612
Most numbers above are close with only a one digit difference, except for the Block and Rear Cover Assemblies, hmmm. So, not sure if this matters much when I order parts. Never ordered for the Pony and figured I would just have to call out the 8U-2042 number. The only other number I see is a stamped plate on the Magneto - MJK 4/2 360-B-410 with S/N 3A 83375. Other than that I don't see anything else unless I'm missin something?
Any help on this is appreciated!!
Scoop from Forestburgh
Fri, Jan 15, 2021 9:58 AM
The numbers you are reading off the parts are actually casting numbers in a lot of cases. You need to go by the parts numbers in the parts book for ordering parts. The difference in numbers between casting and parts usually, but not always, reflect the number of machining operations done to the casting. So if there are no machining operations the casting and part number will be the same. There are always exceptions but that's the general explanation of why casting and part number don't match.
The small filter you refer to is actually connected to the intake runners in the top cover. There is a small hole, about 0.050" diameter that serves as a drain for raw gas that might be discharged from the carburetor. This hole is almost always found to be plugged. Nice to have it functional but not a show stopper.
Fri, Jan 15, 2021 1:42 PM
Scoop
Thank you Old Magnet, can’t tell you how much better that makes me feel knowing a number difference is normal. No sign Pony was ever replaced so I’ll play it straight and stick with part numbers for the 8U-2042 model I have. Will post pics of the rebuild along the way and certain to have more questions! On to the machine shop tomorrow!
Sat, Jan 16, 2021 8:18 AM
Scoop
Reply to Scoop:
Ok, today was a bit of a setback. Unfortunately the bore press at Steve's Machine Shop in Liberty NY came up just a little short on the 22-3/8" wide block. He recommended a couple of nearby shops to consider and I'll check them out on Monday. Said he's been in business over 40 years working on all kind of equipment back to the 20's including heavy machinery and has never got stumped like that. He looked the Pony over and said he would just polish its crank (not cut) and replace the main and crank bearings and that it was time to bore the cylinder, replace the pistons, valves, springs and bushing guides (didn't ask about the connecting rods, thoughts?). My measurements show the cylinders have worn from a Std. Bore of 3.126-3.127" to 3.1368" ( 0.0103" oversize wear), Pistons Skirts worn from Std. 3.120-3.121" to 3.1162" (-.0043" wear) and Piston Lands from Std. 3.106-3.107" to 3.1018" (-0.0047" wear). The compression ring gap when inserted into the bore was 0.065" and should be 0.012-0.022". Animal cruelty!So, the plan is to locate a shop and continue the journey. I'm going to post a bunch of pics her of the tear down to show a few things and ask some questions. New to the forum I'm not sure what the policy might be for posting too much. I ran a test and saw that there is a limit for each reply so I'll do it in a couple of parts.
[attachment=61894]1 - Block (Top).jpg[/attachment]
Block (Top)
[attachment=61895]2 - Block (Front).jpg[/attachment]
Block (Front)
[attachment=61896]3 - Block (Back).jpg[/attachment]
Block (Back)
[attachment=61897]4 - Block (Right).jpg[/attachment]
Block (Right) - Water ports on lower right is clogged
[attachment=61898]5 - Block (Left).jpg[/attachment]
Block (Left) - Water ports on lower left clogged
[attachment=61899]6 - Heads (L,R).jpg[/attachment]
Heads (L,R) - Water ports clogged on lower portion. Machine has been sitting for 18 years with me now and never put to work. Would start regularly until Pony was too difficult to keep running 3 years ago. Machine has remained in a Garage in a Box for last 8-10 years waiting for a Pony rescue. Undercarriage and main engine and other essentials all work good. When running the Pony I would always have to drain coolant out of the heads, one side more than the other can't remember which.
[attachment=61900]7 - Top Cover.jpg[/attachment]
Top Cover - If you look close on right side you will see a hole eaten through the cover where the Starter bracket goes.
[attachment=61901]8 - Top Cover Defect.jpg[/attachment]
Here it is a little closer. Next photo will reveal why ... I think.
[attachment=61902]9 - TC Defect (Polyp).jpg[/attachment]
Bottom side of Top Cover - Defect in casting showing a "Polyp" of iron that didn't make it to where it should have.
[attachment=61903]10 - Top Cover Underside.jpg[/attachment]
Top Cover Underside
[attachment=61904]11 - Crankshaft.jpg[/attachment]
Crankshaft
[attachment=61905]12 - Crank Gear.jpg[/attachment]
Crankshaft - Timing Gear Side
[attachment=61906]13 - Crank Flywheel.jpg[/attachment]
Crankshaft - Flywheel Side
Sun, Jan 17, 2021 10:54 AM
Scoop
Reply to Scoop:
Block (Top)
Block (Front)
Block (Back)
Top Cover Underside
Crankshaft
More pics on teardown:
[attachment=61907]14 - Main Journal CG.jpg[/attachment]
Main Journal - Timing Gear Side; Spec is 1.9995-2.000" with 0.005" out of round. Looks good (I think).
[attachment=61908]16 - Main Journal FW.jpg[/attachment]
Main Journal - Flywheel Side Ok
[attachment=61909]15 - Crank Journal Lft Piston.jpg[/attachment]
Left Connecting Rod Journal; Spec is 1.8745-1.8750" with 0.003" out of round. Ok
[attachment=61910]17 - Crank Journal Rht Piston.jpg[/attachment]
Right Connecting Rod Journal - Ok
[attachment=61911]18 - Main Bearing Flywheel Side.jpg[/attachment]
Main Bearing - Flywheel Side; Some scoring, Replace
[attachment=61912]19 - Main Bearing Timing Gear Side.jpg[/attachment]
Main Bearing - Timing Gear Side; Some scoring but not as bad as TG side; Replace
[attachment=61913]20 - Crank Bearing Left Piston.jpg[/attachment]
Connecting Rod Bearing - Left Piston; Scoring; replace
[attachment=61914]21 - Crank Bearing Right Piston.jpg[/attachment]
Connecting Rod Bearing - Right Piston; Scoring; replace
[attachment=61915]22 - Left Piston and Valves.jpg[/attachment]
Left Piston and Valve Assembly - Best of 4 valves was the Intake shown here, looks new but is only one with a broken spring!
[attachment=61916]23 - Right Piston and Valves.jpg[/attachment]
Right Piston and Valve Assembly
[attachment=61917]24 - Pistons, Valves and Camshaft.jpg[/attachment]
Pistons, Valve Assemblies and Camshaft; Pistons measure wear but do not appear to be severely scorn ...??? Triple checked measurements with difference between cylinder wall and piston skirt of 0.0206" vs 0.006" spec new and piston lands of 0.0350" vs 0.020" spec new.
[attachment=61918]25 - Exhaust Pipe, Flange and Block.jpg[/attachment]
Exhaust Pipe, Flange, and Block; Question - any thoughts on exhaust pipe replacement (2 parts). The parts are discontinued from CAT and expect it will be hard to find and if I find it may be expensive. Plan to ask around but wonder if I shouldn't have made up or idk..
[attachment=61919]26 - Water Pump.jpg[/attachment]
Water Pump; Here's another one. The pulley is worn down to the size of a potato chip on the left. Part is discontinued. Not sure what makes the most sense here, look for it and grab it or can it be built back up??
[attachment=61920]27 - Starter, Starter Pinion, Magneto and Governor.jpg[/attachment]
Starter, Starter Pinion, Magneto and Governor; Last of the teardown parts. If you look at the end of the Starter Pinion you'll see a missing dog ear. Engaging the dozer was a circus ... would have to hold the pinion in from popping out while trying to keep the Pony going and hitting the fuel. Funny but not! Remember seeing the missing dog ear inside the dozer flywheel housing, TG!! CAT wants $282 just for one ear!!! I'm diving back in to find it! lol
Any feedback is appreciated, thank you.
Sun, Jan 17, 2021 1:10 PM
Cat Yellow1
Send a private message to Cat Yellow1
Reply to Scoop:
Scoop - you might be able to find some of those obsolete parts at Florin Tractor. I purchased a pair of pinion latches last year for my D2 much cheaper than Cat wanted.
Sun, Jan 17, 2021 6:38 PM
Thank you received: 77
Reply to Cat Yellow1:
If for some reason you're unable to find the exhaust manifold, a custom exhaust shop will be able to make that up no problem. I used to do a lot of replacements like that, substituting either mild or stainless for the cast tube. Cut the flanges off and reuse.
Mon, Jan 18, 2021 2:16 AM
Scoop
Any suggestions on how to remove head studs without breaking them? Found a machine shop in Port Jervis NY with press large enough to do the job. He’s a one man band and swamped so it’s going to take some time. Suggested I remove the head studs myself and said to be careful if they break it’s going to run into a lot of time and money for him to remove. Said not to heat which is contrary to anything I’ve ever done but I’m nonprofessional just a jack of all trades. Also said to tap block and end of stud with nuts on and take it slow.
Mon, Jan 18, 2021 10:23 PM
Scoop
Reply to Scoop:
Got em all out old school 👍 [attachment=61927]70CEAF7A-725A-4A5A-ADDA-9AA01EC02CD2.jpeg[/attachment]
Tue, Jan 19, 2021 3:22 AM
Scoop
Hey Jon, I attached the Pony motor parts diagram FYI. Looking for part nos. 7F4944 and 5F7647. I’ll call you later, thank you! [attachment=61943]DF8EFB89-8BB0-42F3-8A94-EC02D3D5C503.jpeg[/attachment]
Tue, Jan 19, 2021 9:43 PM
Scoop
Good evening, Anybody know of a machine shop I can send CAT Unfinished Piston p/n 2F-3668 (3.19") to have turned down for my Pony Motor rebuild?  Was able to round up a pair but having trouble finding a shop willing to take the job on. One guy I was recommended to said the last time they did that was about 20 years ago and I got turned away. I understand they are to be turned down round and not cam ground from previous post but am told there is a bit of an OG 3 step process to it in order to do it right. Any help with contact info is appreciated!! Scoop
Sat, Mar 27, 2021 8:25 AM
