D6 8U Modified for Nursery Tree Digging
Showing 1 to 10 of 14 results
IronAppraiser
Send a private message to IronAppraiser
[attachment=31756]039.jpg[/attachment][attachment=31757]035.jpg[/attachment][attachment=31758]042.jpg[/attachment][attachment=31759]046.jpg[/attachment][attachment=31760]045.jpg[/attachment]
This D6 is modified to dig nursery trees. I was in the Yuba City CA. area today where it is sitting next to the nursery, which I assume, owns or rents it. The D6's serial number 8U 1250 SP. There is a camera below the radiator grill which allows the operator a better view of where his alignment with the row of trees is.
Wed, Oct 21, 2015 6:33 AM
Crawler Dollars
I'd be leery to drive over a rock with that high center of mass. Very unique setup for sure. I'd love to see it at work.
Tom
Wed, Oct 21, 2015 6:56 AM
chriscokid
Reply to Crawler Dollars:
Tom
Where's the step ladder?
i have seen D2's and D4's but never a D6 like that, pretty neat but like crawler dollars said i would not want to drive it on anything but level ground.
Wed, Oct 21, 2015 7:28 AM
Reply to chriscokid:
No need to drive it up on the lift for an oil change! lol just walk right under and oil slick yer hair back while yer at it! lol Gosh if Cat made a high clearance like that they would have to have hand rails, cat walks, hyd stepladder, the whole safety shebang and make it look like jungle gym! lol
Wed, Oct 21, 2015 8:15 AM
janmeermans
This is a very unique bit of ingenuity. It took a little thinking by some ranch mechanic.
If you had this on I-5 last week it would not have been swallowed up by the mud and water!
Thanks for posting.
Jan
Wed, Oct 21, 2015 10:41 AM
Thank you received: 288
Reply to janmeermans:
Thanks for posting.
Jan
Glad you took pictures for all to share. My yard is only 2 miles from that digger. I drive past it all the time, but I don't get too close to folks stuff unless I see someone....
Look me up next time you are in the area, I can show you my fleet of jalopies! Thanks again for posting, now I won't have to stop! Lol. Juiceman:rain:
Wed, Oct 21, 2015 11:27 AM
Jack
I've handled a bit of nursery stock, and I can't imagine what they are digging to need that kind of power or size. Did you get any idea what they use it for? Saw logs maybe?
Fri, Oct 23, 2015 10:23 AM
Reply to Jack:
I believe this machine is the first digger my neighboring farmers bought. They raise mainly peach, prune, almond and walnut stock. As they have expanded, I noticed they have upgraded to those GK Machine diggers made in Oregon. Other nurseries nearby have those as well, but I have seen JD 350, Cat D4C and D2 diggers in their early years. Juiceman.
Fri, Oct 23, 2015 10:52 AM
Tracklayer
Send a private message to Tracklayer
I too would be leery of running such a top-heavy machine even with rollover protection. Without such protection, I would not run it. Maybe they have some massive ballast weight positioned out of site on insides of the lower portion of the track frames. But if not, even if the ground were dead level, I can imagine some pitching caused in reaction to that tree spade.
Fri, Oct 23, 2015 10:35 PM
Reply to Tracklayer:
I agree about the safety issue. I have been around some of the other machines, and no such luck on ballast. I was told that some nurseries forbid the operator to drive faster that 1st or low gear. I watched one being loaded on a Cozad trailer; the operator didn't look very happy up there. No ROPS. Maybe that's why nurserymen have gone to those machines from Oregon. Low center of gravity, high clearance, dirt shakers, etc. a much better way.
Fri, Oct 23, 2015 11:21 PM
Thank you received: 138
Hi, Tracklayer and Juiceman.
I think it would probably surprise you just how stable that jigger is. I reckon you would have to get the top of the engine - NOT the hood - out over the outside of whichever was the low track before it would roll. I am not saying that anyone should try cutting or travelling on a 1.5 : 1 batter with it like you can do with a normal D6 8U dozer but I still think it would be quite a bit more stable than you guys are giving it credit for.
And I doubt that I would have any issues with loading it onto a float that was sitting on reasonably level ground. That said though, the easiest way to mount and dismount from the machine might be by helicopter with a winch. Does that nursery have wunna them too? LOL.
Hi, IronAppraiser.
Thanks for sharing, M8. It's always interesting to see the various ways that people have come up with in the past to cope with local issues. Many, MANY moons ago. I posted some photos on ACMOC of a rose harvester down near Wasco. CA., that had TWO Ford diesels mounted on what appeared to be A-C running gear, one over each track, with a clear view down through the middle of the machine to see how many roses you were 'destroying' as you went.
[attachment=31793]Hi-clearance crawler rose harvester with twin Ford diesels - Wasco_1_DP.jpg[/attachment][attachment=31794]Hi-clearance crawler rose harvester with twin Ford diesels - Wasco - Approach_1C_DP.jpg[/attachment]
Sat, Oct 24, 2015 3:03 AM
