D6-8U improper idle
D6-8U improper idle
Showing 1 to 9 of 9 results
Pete P
Send a private message to Pete P
Stumped a bit by my D6-8U.  She starts and runs fine, hits nice and hard on all 6 cylinders under load but when at a slow idle she'll slow down too much (maybe half what it should be) and then 'catch' herself and go back to normal idle -- except for sometimes and then she'll stall.  If I open the throttle just a little (maybe 1/8 throttle) she's fine and keeps a steady idle.
I changed the fuel filters, which were horrible, cleaned the filter housing, bled the system and it's better but not corrected. Ran her skidding logs for about 8 hrs and no change, positive or negative.   I was thinking an injector may be having issues but it hits perfectly on all six under load and is fine idling at even a slightly advanced throttle setting.
Thoughts?
Thanks in advance,
Pete P.
Harborcreek, Penna.
Thu, Aug 4, 2022 1:26 AM
Thank you received: 22
What rpm do you have the idle set to?
What your describing sounds more like worn governor parts.
Thu, Aug 4, 2022 2:07 AM
Pete P
Not sure on the low idle setting -- I've never messed with it and the machine does not have a tach. By ear it might be 600? 700? not real fast but in summer, once the engine is hot she would putter along at dead slow idle for hours.
I've never rebuilt a governor either -- any idea how bad parts are to get?
Pete P.
Thu, Aug 4, 2022 3:15 AM
Reply to Pete P:
Pete P.
Low idle is 550 RPM
I've sort of lost track of governor parts but what is available from Cat is expensive and I don't think governor springs are available any more.
Thu, Aug 4, 2022 3:26 AM
Thank you received: 32
Low idle is 550 RPM
The Cat way to check RPM is at the hour meter with a hand held tach. No idea if one of the new electronic one would work off the little stub. But the hour meter is running half speed of engine RPM,
Thu, Aug 4, 2022 7:47 AM
Thank you received: 42
Reply to Ray54:
optical tachs are not expensive if you can see the crank pulley you can possibly place a bit of the reflective tape on there and get a reading. abw tools put out one and there's a couple of others almost identical. from memory around 100 bucks
we used a optical tach when we were having govenor issues on a southern cross model yb we had fun getting the right sort of pressure spring to make her run smoothly without surging.
Thu, Aug 4, 2022 6:06 PM
TractorDanD2
Send a private message to TractorDanD2
Reply to trainzkid88:
Hi, How's the engine oil pressure under load and at idle? Both cold and hot! The pump could be bleeding some oil pressure internally around the safety for the fuel rack. How's the engine oil? Any signs of fuel dilution ? Cheers
Dan
Mon, Aug 15, 2022 8:18 PM
kracked1
Reply to TractorDanD2:
Dan
Turn the idle up a little. Its very easy to do. There is a half moon cover on top of the governor housing. Remove the cover and the screw twords the front of the machine is low idle. Screw it counter clockwise until it idles smooth at the speed you like. Every time you turn the screw you need to raise the throttle and bring back to idle. The cover locks the screw when you are done.
Mon, Aug 15, 2022 9:54 PM
Dan
[quote="TractorDanD2 post=240091 userid=14830"]Hi, How's the engine oil pressure under load and at idle? Both cold and hot! The pump could be bleeding some oil pressure internally around the safety for the fuel rack. How's the engine oil? Any signs of fuel dilution ? Cheers
Dan
D318 Dozer engines dont have an oil controlled governor.
 [/quote]
Tue, Aug 16, 2022 12:46 AM
TractorDanD2
Dan
 [/quote]
I apologize for that. I got the serial number prefix mixed up. Dan
Fri, Aug 19, 2022 9:31 PM
