D6 8U Governor Settings
NECat
Send a private message to NECat
First I want to say thanks to all the help I’ve gotten on this forum while working on my D6 8U. I got the dozer running last week but it doesn’t have the high rpm’s it had when we pulled it in the shed last fall. I took the back cover off the governor & discovered the spring appeared to be well below the grooves in the rod it coils around. I actually had to push the fuel rack open farther to left with a screwdriver to get enough fuel to start. I assume the spring may have slipped down & should be coiled completely over the grooved rod to allow full fuel rack movement. Traveling for work this week but I should have a D318 service manual in the mailbox at the house I ordered. Any input, suggestions? If there is anyone in eastern Nebraska who has knowledge of these old Cats & getting the governor set, please let me know. Thanks.
Fri, Aug 22, 2025 11:27 AM
Msjoy
Thank you received: 6
I personally cannot shed light on that, but I saw a u tube show on that. Squatch 253 did an excellent job explaining how this worked. Good luck
Fri, Aug 22, 2025 10:02 PM
Thank you received: 67
Yes, that doesn't look right. Different tractor but same basic design - my D2's spring is wound almost all the way up. Lengthening the stroke like that likely prevents the flyweights from going far enough out to permit the high idle rpm
Sat, Aug 23, 2025 12:30 AM
