There are a couple places it possibly can get in so the fuel inj. housing has an "O" ring seal at the top of the housing so it will have to be removed from the filter housing base to replace it. Also while it,s off I,d replace the lip seal at the bottom where the camshaft comes through. Also it could be bad seals in the transfer fuel pump so you,ll have to remove that pump from bottom of the housing & reseal it completely. Also gaskets for both units will need to be replaced. The Cat dealer should have all you need.Don,t forget to shut off the fuel line at the tank before you work on both areas.The injection housing can only go on one way so there is no danger of getting it out of time as the drive tang is offset.When it,s assembled back together you,ll need to bleed the system out to get it started the first time.
